Old 08-15-2018, 05:15 PM   #29
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Pond13 View Post
Do you do much track work? This one does I'm pretty sure. Not saying it is going to happen all the time but I've heard of similar things happening with cats in other non 86/BRZ vehicles. My point was doesn't matter if it's a aftermarket or OEM cat there can still be issues.
Sent from my ANE-LX2J using Tapatalk
I've done autox STX stuff but thats about it, I drive pretty hard on some secluded back roads as well. Your point makes sense, but there's going to be some latent other issue if your blowing out your cat on our cars at under 80k miles imho....
Old 08-15-2018, 05:21 PM   #30
FRSBRZGT86FAN
Originally Posted by localhost View Post
What's the torque spec on those bolts?
The 6 bolts on the header manifold should be 23 ft lbs, and the overpipe to header should be 26 ft lbs. I used a torque wrench and re-did them after a week of hard driving, I still highly recommend high temp rtv on those gaskets though even on the gruppe S some times the flanges aren't perfectly decked and it cuts down on any possibility of leaks.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
localhost (08-15-2018)
catless, catted, header, oft, smell
Catless header exhaust smell? Aegis3425 Engine, Exhaust, Transmission 18 03-18-2020 08:01 PM
Exhaust Fumes/Smell Question/Opinions Mr.Impreza Engine, Exhaust, Transmission 5 05-19-2016 10:57 AM
Header/Exhaust Wrapping Question(s) Strife26 Engine, Exhaust, Transmission 15 12-25-2015 08:11 PM
Question about catless header smell Mr.Impreza Engine, Exhaust, Transmission 26 10-30-2015 11:17 AM
oil smell from exhaust..catless? nickmerronesucks Engine, Exhaust, Transmission 7 07-22-2015 06:44 PM
