Old 08-15-2018, 12:00 AM   #15
When you go catless, everyone behind you suffers. Don't be a selfish asshole. At least keep the secondary, please.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
ChRZ (07-08-2019), nikitopo (08-15-2018), norcalpb (08-15-2018), PandaSPUR (08-15-2018)
Old 08-15-2018, 12:17 AM   #16
Foxy Grandma
Drives: 2016 CWP BRZ
I have an Ace header with the stock front pipe. I get a little bit of fuel smell on cold starts and after running the car hard but otherwise it's not noticeable. Just keep the stock front pipe. You sacrifice 10hp but you don't have to worry about a cheaper high-flow cat pipe breaking.
Foxy Grandma is offline   Reply With Quote
Old 08-15-2018, 12:24 AM   #17
Pond13
Drives: 2013 Toyota 86
You don't need an aftermarket frontpipe/cat for it to break
Sent from my ANE-LX2J using Tapatalk
Pond13 is offline   Reply With Quote
The Following User Says Thank You to Pond13 For This Useful Post:
bababooey (08-15-2018)
Old 08-15-2018, 02:48 AM   #18
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by localhost View Post
But what about at rest? A smell on a cold start makes sense (and is fine), but I'm more curious if there will be a smell when I'm idling at traffic lights or similar.
You're over thinking this, keep stock front pipe and you'll be fine.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
localhost (08-15-2018)
Old 08-15-2018, 02:50 AM   #19
FRSBRZGT86FAN
He definitely messed with the tune in romraider and did the pops and bangs edit and messed something up, I've run e85 with a snap crackle pop tune for exhaust backfiring on overrun and have yet to see any damage to the cat after 40k miles.....
Old 08-15-2018, 02:52 AM   #20
FRSBRZGT86FAN
Yeah that makes sense. I already bought an OFT a month or so ago with the intention of buying a header eventually. I'm fine with the smell while the second cat is warming up - as long as it doesn't get into the cabin after that I'm fine with it.
I think I'll get the Gruppe-S uncatted UEL header in that case then. $650 CAD for it vs $1200 for the JDL catted one I think is a no-brainer.
That's best, the gruppe-s is basically the tomei.
It won't get into the cabin unless you have an exhaust leak, I recommend buying grimmspeed gaskets and high temp RTV and it'll guarantee no leaks and long and you torque it down properly and to spec.
Old 08-15-2018, 03:36 AM   #21
Pond13
Do you do much track work? This one does I'm pretty sure. Not saying it is going to happen all the time but I've heard of similar things happening with cats in other non 86/BRZ vehicles. My point was doesn't matter if it's a aftermarket or OEM cat there can still be issues.
Old 08-15-2018, 05:47 AM   #22
gpvecchi
gpvecchi's Avatar
Originally Posted by Trueweltall View Post
I am completely catless(Gruppe-S, Fujitsubo FP), the smell is not noticeable unless the wind is blowing the exhaust back up to the front of the car when you're stopped, and or at a drive-through. If you can smell it while you're driving you have an exhaust leak into the cabin.
Which cat back? Could you post a video plz?
Old 08-15-2018, 09:39 AM   #23
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Stock catback, it's too loud with my aftermarket catback on the car.
Trueweltall is offline   Reply With Quote
Old 08-15-2018, 12:13 PM   #24
localhost
Drives: Edelbrock SC 2015 FR-S 6MT
Cool, thanks! I think I've made up my mind now - will go with the Gruppe-S with some decent gaskets.
Thanks everyone
localhost is offline   Reply With Quote
The Following User Says Thank You to localhost For This Useful Post:
jflogerzi (08-15-2018)
Old 08-15-2018, 01:05 PM   #25
D-rek07
Not an issue. Leave the stock FP. You'll be fine
D-rek07 is offline   Reply With Quote
The Following User Says Thank You to D-rek07 For This Useful Post:
Old 08-15-2018, 01:51 PM   #26
Trueweltall
Thanks everyone
The exhaust gaskets that come with the Gruppe-S header work fine, no need to spend extra money on different gaskets. I am going on over a year with no leaks, just make sure you torque everything down correctly when you install it.
The Following User Says Thank You to Trueweltall For This Useful Post:
Old 08-15-2018, 02:22 PM   #27
localhost
What's the torque spec on those bolts?
Old 08-15-2018, 02:41 PM   #28
jflogerzi
jflogerzi's Avatar
I just used my impact gun(18 volt cordless) at a lower speed setting
2013 Series 10 FRS #553
catless, catted, header, oft, smell
Catless header exhaust smell? Aegis3425 Engine, Exhaust, Transmission 18 03-18-2020 08:01 PM
Exhaust Fumes/Smell Question/Opinions Mr.Impreza Engine, Exhaust, Transmission 5 05-19-2016 10:57 AM
Header/Exhaust Wrapping Question(s) Strife26 Engine, Exhaust, Transmission 15 12-25-2015 08:11 PM
Question about catless header smell Mr.Impreza Engine, Exhaust, Transmission 26 10-30-2015 11:17 AM
oil smell from exhaust..catless? nickmerronesucks Engine, Exhaust, Transmission 7 07-22-2015 06:44 PM
