Drives: Edelbrock SC 2015 FR-S 6MT
Looking to buy header - question about exhaust fume smell
Hello folks,
I'm seriously considering buying a set of headers for my car and so far I've only been looking at catted headers. Reason for this is that I really hate the smell of exhaust fumes (perhaps more so than regular people), so I thought a catted header would be the way to go with this. However, catted headers tend to run above $1100 CAD while uncatted can be had for a little over half that. My question is, how bad is the exhaust fume smell when running a catless header with the stock catted frontpipe? I'm fine with a faint whiff of it when driving hard, but I really don't want to be able to smell it when I'm just puttering around with regular traffic, or when stopped at a traffic light. I'd rather not spend an extra $500-600 just to get rid of a smell if its only minor. Thanks in advance ![]() For reference, I was looking at the Gruppe-S uncatted UEL header vs the JDL catted UEL header. Last edited by localhost; 08-14-2018 at 05:54 PM. |
#2 |
I have a JDL catless header. I commute in Southern California traffic. The only time I smell it is at startup when letting in warm up in my driveway. Other than that, it is not an issue.
#3 |
It’s pretty bad catless...but my setup also had a high flow secondary cat.
I wouldn’t smell it when I was moving, but coming to a stop with the windows down the smell would totally get in the car. I was catless for nearly 3 years but decided to go back to oem cats/ stage 1 to get a more pleasant driving experience. I may have lost 10hp...but no smell = no regrets. |
| The Following User Says Thank You to norcalpb For This Useful Post: | nikitopo (08-14-2018) |
#4 | |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
After going Catless Front Pipe, I can smell it now, but I don't normally smell it while driving, just every now and then. You really notice if you're standing behind it, loading your trunk or something. I have been considering going HFC Front Pipe.
NARFALICIOUS
Noob Poster 1988 | 2016 |
#5 |
Drives: 2013 Toyota 86
You'll still have a cat in the system so the smell shouldn't be bad. Or go E85, you'll get rid of the petrol smell completely and probably welcome the smell of ethanol on the morning!
Sent from my ANE-LX2J using Tapatalk |
#6 | |
#7 |
This would be perfect for me I think, but now I have conflicting answers from other people. I'm still just as confused as I was when I started haha
#8 | |
It's down to a lot of things like there tune and how sensitive their noses are to smells. I wouldn't buy a header without an OFT or a similar offering from ecutek, more bang for the buck and it makes the mod worth it power wise, and no more CEL or torque dip. As for me with the Stage 2 93 octane tune and CNT uel, with stock front pipe, I couldn't notice any smell. Only on cold starts when the secondary cat is warming up, but editing in a quiet cold start meant it took longer for that cat to warm up as well, but didn't have the ridiculous loud overlap or cold start smell as bad. Running E85 the smell disappeared completely and was replaced with a sweet ethanol smell only in certain situations . I wouldn't worry about the smell honestly, the power increase and the removal of torque dip makes it worth it. Keeping the stock front pipe will definitely help, plus you don't really lose a noticeable amount of power keeping it in a NA setup.
#9 | |
I think I'll get the Gruppe-S uncatted UEL header in that case then. $650 CAD for it vs $1200 for the JDL catted one I think is a no-brainer. |
#10 |
Drives: 2016 Subaru BRZ
I am completely catless(Gruppe-S, Fujitsubo FP), the smell is not noticeable unless the wind is blowing the exhaust back up to the front of the car when you're stopped, and or at a drive-through. If you can smell it while you're driving you have an exhaust leak into the cabin.
#11 |
Best bang for your buck Gruppe-S UEL header and keep stock OP and FP. Smell is only on cold start. After that you don't smell anything. Also if you work with your OFT tune, you can disable the cold start which should help with smell at start. IMO Gruppe-S UEL + used OFT and stock FP,OP over a catted UEL Header any day.
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | FRSBRZGT86FAN (08-15-2018) |
#12 |
Drives: 17 Series Yellow BRZ
Same here. This is 100% the right answer. You'll never smell it when driving.
#13 |
#14 | |
Sent from my ONEPLUS A5010 using Tapatalk
| Tags |
| catless, catted, header, oft, smell |
| Catless header exhaust smell? | Aegis3425 | Engine, Exhaust, Transmission | 18 | 03-18-2020 08:01 PM |
| Exhaust Fumes/Smell Question/Opinions | Mr.Impreza | Engine, Exhaust, Transmission | 5 | 05-19-2016 10:57 AM |
| Header/Exhaust Wrapping Question(s) | Strife26 | Engine, Exhaust, Transmission | 15 | 12-25-2015 08:11 PM |
| Question about catless header smell | Mr.Impreza | Engine, Exhaust, Transmission | 26 | 10-30-2015 11:17 AM |
| oil smell from exhaust..catless? | nickmerronesucks | Engine, Exhaust, Transmission | 7 | 07-22-2015 06:44 PM |
