Old 08-14-2018, 03:16 PM   #323
FymTom
Drives: 16' BRZ
I purchased the dual setup through CSG recently. I did a data log of my daily commute before and after the install. I figured the data may interest some, since I was looking for more.
Car has JDL UEL header ceramic coated, flex fuel kit, and DT tune. Both logs were done on 93oct.
Before Cooler: Ambient Temp 91F, humid day (no RH value)
After Cooler: Ambient Temp 98F, also very humid.
Overall, I'm happy with the dual rad/oil cooler. I'll log temperatures during my upcoming track event as well.
FymTom is offline   Reply With Quote
The Following 8 Users Say Thank You to FymTom For This Useful Post:
Bonburner (09-27-2018), CSG Mike (08-14-2018), CxG (04-08-2019), mrg666 (08-14-2018), new2subaru (08-14-2018), Pat (08-14-2018), Rosticles (08-18-2018), Tristor (09-10-2018)
Old 08-14-2018, 06:30 PM   #324
mrg666
pessimistic skeptic
mrg666's Avatar
Very informative data. Interesting to see that oil temp is dipping below coolant temp when engine is idling with the dual radiator. Probably thermostat for coolant was closed.
Old 08-14-2018, 09:18 PM   #325
mrg666
pessimistic skeptic
mrg666's Avatar
Hmm, I wouldn’t think the thermostat was closed, since the coolant was pretty flat line at 190F. If anything at all, it would’ve ever so partially closed, since they gradually open/close. I wasn’t completely stopped at idle for more than 15-30 seconds. I was probably moving extremely slow stuck in bumper to bumper/1st gear stop and go traffic when the the oil temperature dipped like that. My thought on it was that since I wasnt putting much load/rpm into the engine in that particular spot that heat from the oil naturally transferred into the cooling system (hot moving to cold) as it should. Once the heat transferred into the coolant system it was cooled via the radiator/airflow.
If the thermostat is closed, the coolant is not circulating through the radiator. and the radiator exchanges the heat in oil mostly with air not coolant. As I see now, this dual radiator is a hybrid oil cooler. It is mainly air-to-liquid when the coolant thermostat is closed. Both air-to-liquid and liquid-to-liquid when thermostat is open. Do you think a race thermostat with a lower temperature limit can increase the effectiveness and maybe improve the regulation of oil temperature?
Edit: maybe adding a thermostat for oil line with a temperature limit close to 210F would be good. We don't want oil temperature to go below 200F.
Old 08-14-2018, 10:50 PM   #326
gtengr
Drives: 2017 BRZ
Isn't the oil cooler confined to the radiator end tank?
gtengr is offline   Reply With Quote
Old 08-15-2018, 02:41 AM   #327
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
It would be nice to know what is in the oil cooler side. My guess is that it is something like this trans cooler combo, which is like the Forester XT cooler, but maybe larger in surface area. It kinda begs the question whether this dual setup would perform much different than the Forester XT setup with a larger radiator. It would be nice to know how much more surface area this oil cooler has.
[ame]https://www.youtube.com/watch?v=A65613TaWYw[/ame]
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
jbailey8748 (08-16-2018)
Old 09-02-2018, 05:54 PM   #328
falcon_wizard
Drives: BRZ 2013
Originally Posted by falcon_wizard View Post
Thanks for the feedback, I've just ordered the JR dual cooler and will be able give feedback on how it performs after its installed, but based of the feedback here, I suspect it will be exactly what I need. My Turbo setup puts up to 340hp, if it can bring oil down from 280F down to 240F or less, It'll be just fine for my 5W40 oil.
So I promised I would provide some feedback once the Jackson Dual Cooler was installed.
Initial comparison logs seems very promising. While Oil temp could easily reach 280 degF when driving at high revs before, during a first test with the Dual Oil Cooler, the Highest Oil Temp I reached was 235 degF.
During each test, the engine was maintained largely above 4000 RPM for about a 20min period. Running the engine constantly at 4000 RPM or higher is really where I found an oil cooler to be a must, where Temp would reach 260F very fast (3-4 mins) and up to 280F. Otherwise, in "normal high load" conditions with this turbo set-up, I found the stock cooling system could still be sufficient with the 5W40 Oil I use, where Oil Temp would go up in the 240-250F range but not really beyond that, so not really scary with 5w40, but probably borderline for 0W20. With the Dual Cooler, it seems it will be able to keep my oil under 240F even in worst case conditions and benefit from faster warm up time as well from a cold start or winter, which is great.
It also warms up faster to operating temp (anecdotally about 5 mins versus 9 mins), and since the oil does not go as high, brings it back to normal operating temp much faster after RPM is reduced. Water Temp did not exceed 212F with the Dual cooler, where previously it went typically to 212F and up to 215F worst case. So Adding the Oil Cooler does not seem to be detrimental to Water Temp, with the larger Radiator.
An interesting tidbit is that Oil Temp seems to be mainly a factor of the RPM over time. The Test 2 with the stock cooling system was under higher load than Test 1, but both seemed to influence Oil Temp about the same way when looking at the RPM & time.
In test 1, it took over 13 mins to bring the oil back down from 276F to 220F. With the Dual Cooler, in 5 mins the oil was back down from 230F to 210F.
This is precisely what I was looking for...
Cheers
falcon_wizard is offline   Reply With Quote
The Following 12 Users Say Thank You to falcon_wizard For This Useful Post:
bhmax (11-10-2019), Bonburner (09-27-2018), CxG (04-08-2019), djezlee (09-05-2018), flippy (04-10-2022), gtengr (09-10-2018), Horrid_Funk (09-05-2018), Irace86.2.0 (09-03-2018), new2subaru (09-03-2018), Pat (09-02-2018), Rosticles (09-03-2018), Tristor (09-10-2018)
Old 09-10-2018, 01:21 PM   #329
FymTom
Drives: 16' BRZ
Results with the JR dual setup on track. Was a cool day, 68F or so. This is on e85 for what its worth.
Oil temperature stayed below 230F all day.
The Following 6 Users Say Thank You to FymTom For This Useful Post:
djezlee (09-10-2018), flippy (04-10-2022), gtengr (09-10-2018), Sportsguy83 (09-11-2018), tehShirt (09-11-2018), Tristor (09-10-2018)
Old 09-10-2018, 03:14 PM   #330
djezlee
Drives: 2017 BRZ Limited
What setup do you have? Fi or NA? Hood vents?
djezlee is offline   Reply With Quote
Old 09-10-2018, 03:23 PM   #331
FymTom
Drives: 16' BRZ
Its NA, no vents. Specifics are in post #323.
The Following User Says Thank You to FymTom For This Useful Post:
Old 09-10-2018, 11:03 PM   #332
falcon_wizard
Drives: BRZ 2013
Did you have oil pressure logs as well ? What oil do you use ?
Cheers
Old 09-10-2018, 11:29 PM   #333
FymTom
Drives: 16' BRZ
Cheers
No, I don’t have an oil presssure gauge. Just the stock warning light.
I use Mobil 1 0w-20.
Old 09-13-2018, 08:23 PM   #334
exgladous
Drives: 2017 BRZ PP
Don't have any before/after logs but I can report drops in oil temps from about 220F to 190F on the highway, and from around 245F to 220F on mountain runs (hovering about 6000 rpm constantly). Haven't had the time to track it yet but I suspect this will ease my stress since last time I was hitting over 260F on track.
exgladous is offline   Reply With Quote
The Following User Says Thank You to exgladous For This Useful Post:
CSG Mike (09-13-2018)
Old 09-14-2018, 12:44 PM   #335
Tristor
Tristor's Avatar
I don't think I've previously posted in this thread, but I'm very happy with my Jackson Racing Dual-Rad Oil Cooler. I was peaking ~268F on track before hand and now am peaking ~221F on the track with 25 minute sessions. It also still warms up reasonably quickly just driving on the highway here in Texas.
I've not yet installed any sensors in the sandwich plate but I'm planning on adding an AEM oil pressure gauge and running the pressure sensor from the sandwich plate instead of from the oil gallery plug, we'll see what that ends up looking like at some point in the future.
Tristor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tristor For This Useful Post:
bhmax (11-17-2019), CSG Mike (09-14-2018)
Old 09-15-2018, 05:49 PM   #336
Nawar
Drives: 2016 Red GT86
Hey guys, i heard that if i change my radiator to this one, i would need to get a Transmission cooler. I have an Automatic Gt86.
Cheers
Nawar is offline   Reply With Quote
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
