| Software Tuning Discuss all software tuning topics. |
#15 |
Drives: '15 BRZ RA
#16 | |||
Drives: FT86
Guys it true the ecu has timng compensations tiggered by the amount of knock the knock sensors detect but these compensations have limits This motor is 12.5:1 compression and it needs decient fuel. The minium recomended octane rating is 91 AKI MON (usa) and 95 RON in the european\australian\asian standard. This is from subaru\toyota For best performance you need to un 93 or above MON and 98 or above RON fuels Ive got logs of the stock tunes from peole running on the lower rating fuels ie 91 and 95 and the ecu is getting towards it maxium amount of compensation ie the IAM Advance multiplier as arround 0.2 or 0.3 and it was still getting FLKC knock indications of close to 4 degrees. The IAM will be 1 when on good fuels and its minium value is 0. So with 87 in tank its not going to be pretty your just going to get heaps of knock and the ecu wont have any compensation left. And 87 is way below the minimum standard recomended by subaru\toyota. Here is a log from a srock car running stock tune on 95 RON fuel ie the minuim recomended. This wasnt on track this was jist normal road driving https://datazap.me/u/steve99/south-a...8&solo=2-13-28 Last edited by steve99; 08-06-2018 at 11:14 AM. |
| The Following 5 Users Say Thank You to steve99 For This Useful Post: | ayau (08-09-2018), FRSBRZGT86FAN (08-09-2018), JohnJuan (08-09-2018), nikitopo (08-06-2018), Ultramaroon (08-08-2018) |
#17 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If you're going that far off the map, you may lose your twin in a pothole.
I'd rent a Suzuki Jimney that can handle the circumstances and is designed to run on low octane fuel. Maybe a Hilux if you need auxiliary security personnel.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | JohnJuan (08-09-2018) |
#18 |
#19 |
#20 | |
Steve, thanks for more technical insight. This is why I asked for OFT map which would eliminate knocking. For that leg of the trip, power does not matter. I wonder though, in case I will not be able to get a map, if driving style (never WOT, stay below 4k RPM) would help eliminate some of results of using low grade fuel. |
#21 |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#22 | |
I suggest you have one of these follow you, then it can give you ride back to civilization when your BRZ fails. Oh, don't forget to have this vehicle tow a gasoline trailer. humfrz |
#23 | |
Drive it to Ft Irwin, CA and drive it around for a few thousand miles. Arrange for the post POL to air drop a couple of 5 gallon Gerry cans of gasoline every now and then. Then when your BRZ gives up, call for a CH-47 (Chinook) to extract you and whatever is left of your machine. ![]() humfrz |
#24 | |
By 1000-2000k miles I meant no 91 or better gas. Ppl still live there. |
#25 |
If Fiat Panda made it (again it is not a troll), I should be able too. And I do have an advantage being 2 wheel driven (as opposed to 1 wheel for the most of cars). Odds that I will get suck are lower than getting TB in first 50k (s)miles.Which I replace as a preventive maintenance before the trip.
#26 |
LMGTFY
Drives: 13 FRS, 91 Miata
The more I hear, the more it feels like a Top Gear Challenge.
| The Following User Says Thank You to x808drifter For This Useful Post: | ajcarson11 (08-13-2018) |
#27 |
[insert cool phrase here]
Drives: BRZ Premium
Sounds like your better off buying a small tow trailer or extended hitch and a few jerry cans of your preferred gas.
By the way you sound, are you Canadian eh?
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#28 | |
![]() ![]() humfrz |
| mixing e85 (109 octane) with e15 (91 octane) | pcguru2000 | Engine, Exhaust, Transmission | 19 | 03-08-2022 11:35 PM |
| 100 Octane? | hellyvin | Northern California | 23 | 07-24-2017 09:01 PM |
| Do you use 93% octane | RichardsFRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 62 | 02-09-2016 12:21 AM |
| 100 octane race gas: 91 octane ratio? | GhostofAkina | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 02-08-2013 02:23 AM |
| 93 Octane? | ashtray | BRZ First-Gen (2012+) — General Topics | 175 | 04-04-2012 01:22 PM |
