Old 07-09-2018, 01:15 PM   #169
AJPG
Drives: 22RE, FA20, 4G63
Originally Posted by swift996 View Post
I wanted to make an archive of people's best dyno run with their configuration.
Please ONLY POST a DYNO (there is no need to comment)
Format:
- Name/Screen Name
- Force Inducted Kit
- Fuel Type
- Max Boost
- Other Mods
- Other Notes/Conditions, Tuner, etc. (include link to other thread where people can go comment/ask questions if desired)
- PIC OF DYNO
If you have any comments or suggestions feel free to PM me, let's try and keep this clean and a valuable resource.
/\ This
AJPG is offline   Reply With Quote
Old 07-10-2018, 11:10 PM   #170
xwd
TRD supercharger
12.5:1 built motor, lots of other stuff
~9psi. This is the largest pulley, I have 3 smaller ones.
Very conservative tune on E50, will tune more aggressively once there are more miles on the engine.
Ignore some of the mess in the engine bay, still very much a work in progress.
Old 07-10-2018, 11:42 PM   #171
StraightOuttaCanadaEh
Wes
Trd supercharger? Where did that come from
Instagram: @gt86ws
Old 07-27-2018, 09:54 PM   #172
chazmuska
chazmuska's Avatar
Drives: 2014 Scion FR-S
Can someone please explain this?
How does this dyno graph go backwards? wtf
Its from this video: [ame]https://www.youtube.com/watch?v=mcUsV7fE4Bs[/ame]
chazmuska is offline   Reply With Quote
Old 10-14-2018, 05:03 PM   #173
Kalebhall
Drives: 2013 Subaru BRZ limited
278 whp
-CX racing turbo kit 6.6 psi
-stock fueling
-muffler delete
-91 pump
Kalebhall is offline   Reply With Quote
Old 11-19-2018, 12:24 PM   #174
eMCee
eMCee's Avatar
Drives: GT86
- Cosworth Supercharger 2.0 on 98RON map,
- 102RON fuel in the tank
- not sure about the boost values, no smaller pulley,
- stock engine, stock exhaust, Cosworth Air Filter,
eMCee is offline   Reply With Quote
Old 12-11-2018, 03:32 PM   #175
yourboyvic
Drives: brz
please update?
David Agrait / Sportsguy83
- AVO Stage 2+ Turbo Kit
- 93 Octane/SIR 500cc Port Injectors/DW 65c Fuel Pump
- 14 psi
- AVO 18/49 Oil/Water Cooled Turbo (TD05 18g) internally gated, AVO 50/50 BOV, Perrin Manual Boost Controller, Nameless 3" OP/DP, Midpipe and Axleback, Clutchmasters FX350 Clutch Kit, D3 Performance Engineering Catch Can
- 90F+ Temps and Rain, 4th Gear Pulls.
- Will be doing E85 Dyno tune soon, will update post with new numbers ASAP.
- Turbo Experience Thread
- Member Car Journal
please update?
yourboyvic is offline   Reply With Quote
Old 12-11-2018, 03:53 PM   #176
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by yourboyvic View Post
please update?
I don't know wat google did but they f'd up a bunch of my pictures....
The car made right at 300 whp that day. It's vastly different now with a V8 swap.
Old 12-16-2018, 09:14 PM   #177
xwd
TRD SC update. Went from a 100mm pulley to 95mm, gained about 40hp and 30ft-lbs, peak was around 11.5psi. I have 90, 85, and 80mm pulleys left still. I think the highest run of the day was 347/268. This is on E75.
Old 12-26-2018, 11:45 AM   #178
diluzio91
Drives: '13 with go fast bits attached
-Edelbrock Supercharger
-92 Oct Pump gas
-Stock Pulley
-Gruppe S UEL header, ECUTek tune, Magnaflow Catback
-Note : Clutch began slipping before tuning was complete. Blue line is headers and tune only. Will update after clutch and re-tune.
diluzio91 is offline   Reply With Quote
Old 12-28-2018, 09:58 AM   #179
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
-SBD 500x turbo kit
-100ron / all stock fuel system
- red : 12psi , blue: 11psi
- 2.25 exhaust with 1 cat , dual catch can, turbosmart EBC , ORC clutch, STI maf sensor
- 4th gear pull , self tune via OFT
- stock 86 made 170WHP on same dyno.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 12-28-2018, 10:17 AM   #180
tomm.brz
Drives: brz 2017 hksv2
@Yobiwan , you had the hks v2 with 45mm restrictor, why the change?
Old 12-28-2018, 04:08 PM   #181
Yobiwan
Yobiwan's Avatar
Nothing wrong with hks kit. I sell it to my friend, and it runs flawlessly.
I just want to know difference between HKS supercharger and SBD 500x.
I feel 500x is better in every aspect of driving
and make more power at same psi than HKS supercharger.
My best dyno number with hks v2 was about 270 whp
Old 12-28-2018, 04:31 PM   #182
tomm.brz
Cool happy for You
I m waiting to install the hks v2 (the new one with black housing arrived to me last week) with 44mm
Can you please post the dyno of Your hks kit You had here for me? Are those wheel hp right?
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
