Old 07-26-2018, 03:56 AM   #1
neroman98
Drives: 2014 Scion FRS Track Build
Rear Axle is stuck in diff
Hey guys,
I’m trying to remove the diff so I can swap it for an OS Giken but I can’t get my axle to pop out from the diff. The diff is still installed so that I can use a pry bar with leverage and I know that I’m supposed to pop it out like half an inch or so and then actually remove them once I drop the diff, but the axles will not budge one bit from the diff. I have no idea what to do. I’ve tried even using a metal mallet to bang on the pry bar and it still will not budge.
What am I doing wrong??? Any tips/ideas are greatly appreciated.
Thank you.
neroman98 is offline   Reply With Quote
Old 07-26-2018, 09:21 AM   #2
wparsons
wparsons's Avatar
Dumb question, but did you take the other end of the axle out of the hub first? There isn't enough room to get the axle out with both ends still contained.
flickr
Old 07-26-2018, 09:47 AM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Originally Posted by neroman98 View Post
Hey guys,
Thank you.
Get a bigger hammer...seriously. Make sure you are hitting it in the right place (see pic). Watch this video around the 5:30 mark. He's using a screwdriver but I used a piece of steel that had a bit more substance to it and a 3 pound sledge. Don't try to "pry" it out, you have to "drive" it out just like he's hitting the screwdriver in the video. It will pop out.
[ame]https://www.youtube.com/watch?v=NIrNabUpQXY[/ame]
BirdTRD is offline   Reply With Quote
Old 07-26-2018, 11:24 AM   #4
neroman98
I’m not sure what you mean? I haven’t been able to get either side out.
Old 07-26-2018, 02:30 PM   #5
neroman98
So for anyone who was stuck like I was: i was using a pry bar to get it out and had no luck. I finally decided to go down to Harbor Freight and buy the correct tool, an axle remover, for $10. Its like a metal fork with two prongs. Two hits with the 5lb hammer and it came out super easy.
DO NOT SPEND THREE HOURS TRYING TO SOLVE THIS LIKE I DID, JUST GO BUY THE TOOL. I will link a listing for a similar tool below but the one I got was just a random $10 one.
https://www.shop.com/STECK+71410+Axl...xoCDq4QAvD_BwE
Hope this helps!
The Following 3 Users Say Thank You to neroman98 For This Useful Post:
CSG Mike (07-27-2018), Tristor (07-31-2018), Trust86 (07-26-2018)
Old 07-26-2018, 02:33 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Glad you got it out. Back in my Honda days I used a slide hammer that worked great.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-26-2018, 02:45 PM   #7
Trust86
Drives: 2016 Halo FRS
Axles don’t like to pop out hitting or prying on one side. They will, but much easier using equal amounts of force on both sides. When you hit or pry on one side, you’re making it “tighter” on the opposite side.
Trust86 is offline   Reply With Quote
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 11:23 AM
Leaky axle/diff seal? slyphen Issues | Warranty | Recalls / TSB 28 03-01-2018 02:30 PM
Transmission won't engage any gears.. Diff/Axle is done. Rifle Issues | Warranty | Recalls / TSB 35 03-29-2016 01:36 PM
Rear Diff axle removal xsnapshot Engine, Exhaust, Transmission 11 01-08-2016 01:28 PM
Diff whine with clutch engaged + axle seepage Laika Issues | Warranty | Recalls / TSB 33 10-11-2014 09:16 PM
