#2843 |
#2844 | |
Drives: 2014 BRZ Limited
Unfortunately, E-85 isn't readily available where I reside so fueling is limited to 93 octane. I'm also not looking to break any records. So if the general consensus is that 3" will net minimal gains unless I'm trying to extract the absolute last drop then I think I should be set with my path forward! Appreciate your input! -Carlos |
#2845 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I haven't had any experience with other headers, but I have the coated ACE A350 header and touring 86 exhaust, some people don't like it, but its perfect for me. It's fairly quiet during cruise and sounds sooo sexy at WOT. I even had a modified M2 owner come up and comment on how much he loved it.
| The Following 2 Users Say Thank You to B T For This Useful Post: | Carlos_M (07-18-2018), HachiRokuX (12-02-2018) |
#2846 | |
If your header's outlet is 63mm (as are most headers'), then going larger that doesn't do anything; the tightest point is still 63mm. |
#2847 | |
Drives: 2013 Black FR-S
#2848 |
Drives: 86
Logs are showing manifold absolute pressure around 1.75 bar right at my redline of 7500, so a peak of 10-11 psi. Note Delicious and most tuners recommend safely extending redline slightly and I would net more power doing so -but I've requested my redline remain at 7500.
Here's a graph of the MAP and RPM from a WOT log on my car with the tune it ran on the dyno. Hope this helps! |
| The Following User Says Thank You to Colin86 For This Useful Post: | gtengr (07-21-2018) |
#2849 |
Judson
Drives: 15 FRS 6spd Edelbrock SC
The stock fuel system is beefier than you think...
First off, I'll say again this kit has blown my expectations out of the water. I've been driving around on a Delicious tune, but recently took her in to get a nice dyno tune. I'm still running the STOCK fuel system and standard 3.25 inch pulley that comes with the kit, and Forged performance reached in and pulled 311whp out of her! Not only that, she makes close to peak torque from 3.5k all the way to redline, on 93 pump gas! If only there were an e85 station closer than 12.7 miles from me.....
| The Following User Says Thank You to jordanthebass For This Useful Post: | gtengr (07-22-2018) |
#2850 | |
Drives: '17 Toyota 86
Sent from my SM-N950U using Tapatalk |
#2851 | |
Drives: 13 FRS Firestorm
I'm also interested on what mods Jordanthebass has. Forged performance is might be the nearest tuner to me. |
#2852 |
#2853 |
Judson
Well I am running a pair of catless uel headers and a full 2.5 inch exhaust, an oil cooler which keeps the oil temp perfect at all times. (Probably not necessary but Atlanta can get dangerously hot in July). Other than that I haven't touched the anything regarding fueling and/or electrical. If you'd like the details I'd love to share perhaps outside this thread so I don't clog it up
| The Following User Says Thank You to jordanthebass For This Useful Post: | BertoFT (07-25-2018) |
#2854 |
Judson
#2855 |
Drives: 2017 BRZ Special Edition
OFT for the supercharger? for non-ecutek users
Is possible to write the tuned SC file as OFT with openflash?
#2856 | |
Drives: 2014 Porsche Cayman S
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
