Drives: FR-S Turbo
Any solutions to overheating coilpacks?
What is the current thinking on how to avoid this problem at the track?
Would a front-mounted duct the directs airflow to that area help? Has anybody tried this? I'm running the Varis V2 hood, which has great ventilation but also a NACA duct between the 2 banks of vents. The airflow from this is directed down across the back of the engine, but I may be able to redirect airflow from there to the coilpacks. |
#2 |
Even with a vented hood, the problem will not go away on early model cars.
These are much more durable, and have an added benefit of a stronger spark. https://www.counterspacegarage.com/i...set-ip-a149401 |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#3 |
Drives: 2014 Subaru BRZ
The dealer replaced my entire wiring harness under warranty, and that fixed my coil pack issues on my 2014 BRZ (it's been almost a full year and I've done more than a dozen track days since then, including ones where the temps got higher than 100F here in Texas).
| The Following User Says Thank You to 14stu For This Useful Post: | solidONE (08-08-2018) |
#4 |
Drives: 2013 Firestorm FR-S
Since I installed hood vents (trackspec) I haven't had the issue again on my '13.
#5 |
| The Following User Says Thank You to ermax For This Useful Post: | Turbo (07-25-2018) |
#6 |
Usually. I'd caveat my experience that I found it happened when it was a) a particularly high speed track, b) long sessions, c) pretty hot day. Since installing them I haven't had all three variables at the track.
| The Following User Says Thank You to ajh88 For This Useful Post: | Turbo (07-25-2018) |
#7 | |
I'm surprised no one has done a kit to replace our POS coils with cheap GM coils. |
#8 |
Drives: 2013 Panda ft86/FRS
Interesting you say that,as I am actually doing that with some msd ls3 coils and gonna run magnacore wires. I've already tested and they work, I may make a kit.......
#9 | |
The D585 with the heat sink seems like a good option and I see a bunch of brackets for the D585 on Amazon for $49. That actually gives you two brackets so you could sell off one of the brackets to recoup the expense. It’s just a matter of figuring out the wiring. Preferably in a plug in play way where you don’t have to splice into the original wiring. Having the coils remotely mounted would also be really nice for when one goes bad you don’t have to break your hands trying to fit them down in the original location. Something tells me the D585 wouldn’t have heat problems. |
| The Following User Says Thank You to ermax For This Useful Post: | 1quickchic (08-08-2018) |
#10 |
Drives: FR-S Whiteout
Yet another good reason to trade in my MY13 with expired warranty...
Intent > Content
cowardice is the mother of cruelty. |
#11 |
I had read here that the revised 652 coilpack fixed the issue on the 13/14 cars. Is that not the case?
| The Following User Says Thank You to Enkrow For This Useful Post: | Turbo (08-16-2018) |
#12 | |
Drives: Moped
Bump for anyone with further clarity/insight on this question. |
| open flash tablet overheating | J41v33 | Software Tuning | 17 | 04-14-2018 08:01 AM |
| FS: 2014 Coilpacks | Kayysonie | Engine, Exhaust, Bolt-Ons | 9 | 01-11-2018 10:35 AM |
| Overheating stick shift | sj30jet | Engine, Exhaust, Transmission | 8 | 06-12-2017 02:03 PM |
| BRZ overheating | Notso | BRZ First-Gen (2012+) — General Topics | 67 | 06-25-2016 01:01 PM |
| Massive Overheating Incident | mitosis | Issues | Warranty | Recalls / TSB | 26 | 11-18-2013 08:12 AM |
