5w-30 User
Drives: blek
NA Motor Can Handle 350 Crank HP?
EDIT: NA meaning STOCK INTERNALS
Specs: 2013 Scion FRS w/ 70k miles Goal: -Achieve 280-300 wheel horsepower without building or upgrading the motor -Intentions of NO track time, spirited daily driving, racing every now and then -Currently at 70k miles, would most likely install the kit at 80k miles... Need the car to be reliable and last at least 150k miles Background: -Working with my local tuning shop in Northern VA, PTuning -Budget: 7-8k -Cannot install myself, need to pay for labor Questions: 1. Should I go Super Charger route or Turbo? 2.Turbo = PTuning, SC = Edelbrock? 3. Flex Fuel necessary for contribution of 350 crank? 4. UEL / EL Catless necessary for contribution of 350 crank? (Emissions is big in northern VA) 5. Will my car be able to withstand this up until 150k miles? Realistically, when would it blow? Last edited by sxlx; 07-25-2018 at 02:04 AM. |
#2 |
Panda Trueno
Drives: No twin now.
This is common......
| The Following User Says Thank You to Summerwolf For This Useful Post: | SuperTom (07-25-2018) |
#3 |
Drives: C5, GT-86, '24 Colorado TrailBoss
man you are going to blow the welds on the manifold
| The Following 4 Users Say Thank You to SuperTom For This Useful Post: |
#4 |
5w-30 User
Drives: blek
#5 |
#6 |
5w-30 User
Drives: blek
So I'm looking to get 280-300 wheel horsepower. Is that optimal for stock internals or do I need to tone it down? Goal is speed and longevity. I want it to handle like a Porsche and have the power of a Mustang GT. Ofc it won't be as fast, but I want it to at least be faster than a 370z nismo stock since power to weight ratio.
#7 |
5w-30 User
Drives: blek
Specs:
2013 Scion FRS w/ 70k miles Goal: -Achieve 280-300 wheel horsepower without building or upgrading the motor -Intentions of NO track time, spirited daily driving, racing every now and then -Currently at 70k miles, would most likely install the kit at 80k miles... Need the car to be reliable and last at least 150k miles Background: -Working with my local tuning shop in Northern VA, PTuning -Budget: 7-8k -Cannot install myself, need to pay for labor Questions: 1. Should I go Super Charger route or Turbo? 2.Turbo = PTuning, SC = Edelbrock? 3. Flex Fuel necessary for contribution of 350 crank? 4. UEL / EL Catless necessary for contribution of 350 crank? (Emissions is big in northern VA) 5. Will my car be able to withstand this up until 150k miles? Realistically, when would it blow? |
#8 |
5w-30 User
Drives: blek
Specs:
#9 | |
| The Following User Says Thank You to SuperTom For This Useful Post: | Summerwolf (07-25-2018) |
#10 |
Drives: 2016 FR-S
Your local tuning shop puts out a great turbo kit. Go talk to them and they will guide you. You’re looking at 8-10k for everything since you’re not installing yourself.
#11 |
5w-30 User
Drives: blek
I did talk to them. I discussed it with them in the shop today. They're asking for 11,000 with some other minor things. It is just not optimal for me to spend that much for a turbo. Plus I'd prefer naturally aspirated anyway. I just want to know if the FA20 stock internals can handle a supercharger that pushes 350 crank / 300 wheel.
#12 |
Drives: Toyota GTS 86
In my view the answer is no, not reliably. Bent all 4 rods at 240 rwkw (320whp) after 7,000km.
It's a sh*!load of fun to drive though. |
| The Following 2 Users Say Thank You to Hags86 For This Useful Post: |
#13 |
Drives: Panda FR-S
Just keep the torque below 250 wtq and you will be fine. And go SC with flex fuel.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#14 |
Drives: 2015 FR-S
Why did you post this exact same thing in three separate areas in here?
| The Following 2 Users Say Thank You to Impureclient For This Useful Post: | FRSBRZGT86FAN (07-25-2018), why? (07-25-2018) |
| Second time crank seal leak possible crank walk | kiichiro | Engine, Exhaust, Transmission | 13 | 09-19-2018 05:57 AM |
| How much HP can the stock motor handle? | FullTuneZN6 | Engine, Exhaust, Transmission | 34 | 11-16-2017 01:22 AM |
| Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 02:39 PM |
| ooh S%#t handle | Blue14inTracy | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 04-14-2014 06:17 PM |
