Old 07-13-2018, 02:56 PM   #1
Turbo
Drives: FR-S Turbo
Any solutions to overheating coilpacks?
What is the current thinking on how to avoid this problem at the track?
Would a front-mounted duct the directs airflow to that area help? Has anybody tried this?
I'm running the Varis V2 hood, which has great ventilation but also a NACA duct between the 2 banks of vents. The airflow from this is directed down across the back of the engine, but I may be able to redirect airflow from there to the coilpacks.
Turbo is offline   Reply With Quote
Old 07-14-2018, 01:18 AM   #2
CSG Mike
CSG Mike's Avatar
Even with a vented hood, the problem will not go away on early model cars.
These are much more durable, and have an added benefit of a stronger spark.
https://www.counterspacegarage.com/i...set-ip-a149401
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
FirstWinter (07-14-2018), juliog (07-26-2018), Lonewolf (12-22-2018)
Old 07-14-2018, 01:31 AM   #3
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
The dealer replaced my entire wiring harness under warranty, and that fixed my coil pack issues on my 2014 BRZ (it's been almost a full year and I've done more than a dozen track days since then, including ones where the temps got higher than 100F here in Texas).
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
solidONE (08-08-2018)
Old 07-23-2018, 01:47 PM   #4
ajh88
Drives: 2013 Firestorm FR-S
Since I installed hood vents (trackspec) I haven't had the issue again on my '13.
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
The Following 2 Users Say Thank You to ajh88 For This Useful Post:
CSG Mike (07-23-2018), Turbo (07-25-2018)
Old 07-23-2018, 02:55 PM   #5
ermax
ermax's Avatar
I'm curious, did you pop your hood between sessions previously?
The Following User Says Thank You to ermax For This Useful Post:
Turbo (07-25-2018)
Old 07-25-2018, 03:55 PM   #6
ajh88
Usually. I'd caveat my experience that I found it happened when it was a) a particularly high speed track, b) long sessions, c) pretty hot day. Since installing them I haven't had all three variables at the track.
2013 Firestorm FRS
The Following User Says Thank You to ajh88 For This Useful Post:
Turbo (07-25-2018)
Old 07-25-2018, 04:04 PM   #7
ermax
ermax's Avatar
I ask because it seems like it would be the heat soak between sessions would have a big impact. Maybe run the fans with the hood open would be helpful.
I'm surprised no one has done a kit to replace our POS coils with cheap GM coils.
Turbo (07-25-2018)
Old 08-08-2018, 02:33 AM   #8
1quickchic
Drives: 2013 Panda ft86/FRS
Interesting you say that,as I am actually doing that with some msd ls3 coils and gonna run magnacore wires. I've already tested and they work, I may make a kit.......
1quickchic is offline   Reply With Quote
Old 08-08-2018, 12:40 PM   #9
ermax
ermax's Avatar
The D585 with the heat sink seems like a good option and I see a bunch of brackets for the D585 on Amazon for $49. That actually gives you two brackets so you could sell off one of the brackets to recoup the expense. It’s just a matter of figuring out the wiring. Preferably in a plug in play way where you don’t have to splice into the original wiring. Having the coils remotely mounted would also be really nice for when one goes bad you don’t have to break your hands trying to fit them down in the original location. Something tells me the D585 wouldn’t have heat problems.
1quickchic (08-08-2018)
Old 08-08-2018, 08:49 PM   #10
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yet another good reason to trade in my MY13 with expired warranty...
Intent > Content
Old 08-15-2018, 02:32 PM   #11
Enkrow
Enkrow's Avatar
I had read here that the revised 652 coilpack fixed the issue on the 13/14 cars. Is that not the case?
Enkrow is offline   Reply With Quote
The Following User Says Thank You to Enkrow For This Useful Post:
Turbo (08-16-2018)
Old 12-22-2018, 12:36 AM   #12
Lonewolf
Lonewolf's Avatar
Drives: Moped
Bump for anyone with further clarity/insight on this question.
open flash tablet overheating J41v33 Software Tuning 17 04-14-2018 08:01 AM
FS: 2014 Coilpacks Kayysonie Engine, Exhaust, Bolt-Ons 9 01-11-2018 10:35 AM
Overheating stick shift sj30jet Engine, Exhaust, Transmission 8 06-12-2017 02:03 PM
BRZ overheating Notso BRZ First-Gen (2012+) — General Topics 67 06-25-2016 01:01 PM
Massive Overheating Incident mitosis Issues | Warranty | Recalls / TSB 26 11-18-2013 08:12 AM
