#1205 |
Drives: Subaru BRZ 2017 PP
Hello,
I am about to marry OFT to my car for the first time. I have a 17 BRZ. I noticed the first post mentions to select Ft86, and if that doesn't work to select BRZ/FRS. Should I still follow that tip and select Toyota->FT86 as my vehicle when marrying, even though I have a brz? Or should I select the brz option first? not sure if it matters, I just don't wanna mess up marrying my car for the first time. Thanks |
#1206 | |
Drives: FT86
Use which ever option works toyota 86 or brz or frs the ecu are all same |
#1207 |
Drives: BRZ, E90 M3
Hi,
I am looking for some advice about the OFT v2. I have plugged the tablet into my BRZ's OBDII port and the "Read" button is grey out. I tried to write a tune and I am receiving an error code that displays "ECU number mismatching ECU Write Denied". This in retrospect shouldn't have been done. The previous owner's VIN is still logged and unfortunately the previous owner no longer has the car. I have tried to take on some self resolution for my issue by updating the tablet to the latest version of software. I tried to use the Erase Data function in the Open Flash Manager desktop app was not able erase the data unfortunately. A suggestion to resolve this error would be greatly appreciated. Thank you so much for your time! |
#1208 | |
Drives: FT86
So ds like tablet still married to other guys car If he hasnt written back stock tune beforeche sold it to you is basicly a brick See first post in this post about un marying tablet |
#1209 | |
Drives: BRZ, E90 M3
We're good to go. The car wasn't sold yet by the dealership and was able to write back to stock. The tablet is now married to my car. Thank you for the response! |
| The Following User Says Thank You to hachigoku For This Useful Post: | steve99 (07-23-2018) |
#1210 |
Drives: 2014 BRZ Sport Tech
Anyone have the tablet mounted in the car somewhere to datalog? I can’t figure out where to put it and the cable supplied is too short and gets in the way of driving.
#1211 | |
TRACKBREAD
Open Flash Tablet - OFT TIPS Trick’s & FAQ
You can find a $10 OBD extension cord at Amazon. I have that snaked behind my dash so the cable comes out by the A pillar. Then a suction cup to the windshield. You can also wire a switch on the power wire of the extension, that way you can turn the tablet off if you're leaving he car parked for a few days. |
#1212 |
Enthusiast
Drives: 2013 BRZ Limited
hi!
how important is the secondary O2 sensor? i've got 1320 performance uel manifold ant the hole for second O2 sensor is positioned so it's very hard to put sensor in properly, it hits the frame. so i'm using provided extension which is bended 90 degrees (and usually is used for tricking the sensor), but i'm afraid that now oft tune will not get proper readings from it. thanks! |
#1213 | |
Drives: FT86
It should be ok as the rear o2 is not primary fueling sensor. The rear is only ised for cat efficiency check ( disabled in most tumes) and cruise fueling. Monotor AF#3 correction if you see anything over a couple of percent then you may need to disable AF#3 corrections. But spacer in REAR 02 sensor is generally ok |
#1214 | |
Drives: raven widebody
#1215 |
Hi, would like to know if anyone bought OFT and uses in Asia country like Singapore?
#1216 |
Drives: 2016 GT86 N/A
My car was totaled. Can I use OFT on other car without unmarring it?
My car was totaled / written off by insurance. I don't have access to it anymore.. Can I use OFT on other car without having access to the car's ECU it was married to? Is there any other way to reset it to 'unmarried' ?
Thank you. |
#1217 | |
Drives: 2016 Subaru BRZ
However now it behaves exactly as described. You click "tuning" and it gives the mismatch error, you plug it into OpenFlash Manager and it claims it's not married to anything. Properly communicates with the ECU, pulls the version and whatnot just fine, but refuses to either be updated or to give access to the Tuning menu. I've opened a ticket with openflashtuning but it sounds like that may not be the right way to get ahold of the company? |
#1218 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Getting a non-compliant error
BIN files won't load into OFT. Error says file is non complaint. I've had little success reading their FAQs. I'm waiting for an email reply from OFT tech but they tell me it could be two days at least. No phone support is a bummer.
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
