#85 |
Except many of them were gaskets. I unsuccessfully slopped on a lot of goop before learning to properly clean the mating surfaces. Then, years later in college, I learned a little about how adhesives work the way they do.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (07-17-2018) |
#86 | |
Especially working in an old, dark, drafty, cold barn, with a dirt floor, with a coal oil lamp for light. ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (07-17-2018) |
#87 | |
#88 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I've struggled through this entire thread, wondering if I made a wise choice by buying a 2014 with 30,000 miles on it. I don't know if there are any stats anywhere showing a percentage of these cars with spun bearings. I know if I had any thoughts about FI before, I don't now. I also have to rethink my oil philosophy. I put Mobil-1 0W30 in it right after I got it. But that's primarily because it gets so hot in Florida. I usually change oil in my cars at 5000 miles. Maybe I'll shorten that up a bit. My first planned addition was oil temp and pressure gauges. I'm raising that to critical status.
#89 |
Famous Potatoes
Drives: '15 ultramarine
| The Following User Says Thank You to Sapphireho For This Useful Post: | Ultramaroon (07-18-2018) |
#90 | |
![]() Then, I'll betcha if you do get oil temperature and pressure gauges, they will just give you more numbers to fret over. ![]() humfrz |
#91 |
#92 | |
No, I suspect the overall percentage of spun bearings is quite low, but there doesn't seem to be a consensus on that in this thread. Admittedly the subject here has been more about the possible cause, rather than frequency. I'll take the car to the track a few days a year and use it as my DD, which means it will get pretty well thrashed every day. I'm coming off 180,000 miles on a pair of Miatas over a 14-year period with no internal engine problems. Maybe I just got spoiled. |
#93 | |
humfrz |
#94 | |
Drives: toyota 86 2017
Better grab hold of your ankles if you are going to ask the dealer for the trade in value without seeing what others will give you. Your best bet is to go to carmax (if you have one by you), get a quote (it's good for a week) on what they'll buy it from you. Then go to the dealer and see what they will negotiate for the car price first, tell them you might be trading in the car. Keep in mind that they will know all the issues with the car and see where you come out ahead. |
| Stock Motor is Toast (Spun Rod Bearing) | DFW-FRS | Issues | Warranty | Recalls / TSB | 78 | 02-13-2018 12:56 PM |
| FS: 2013 FA20 engine w/spun bearing | Bullnettles | Engine, Exhaust, Bolt-Ons | 9 | 04-05-2017 07:39 PM |
| Engine failure - Spun rod bearing TWICE | dinoniel | Issues | Warranty | Recalls / TSB | 38 | 11-07-2016 02:17 PM |
| Spun Rod Bearing #4 | KE70 | Issues | Warranty | Recalls / TSB | 13 | 07-05-2016 04:17 PM |
| Likely hood of a spun bearing | aquaman | Engine, Exhaust, Transmission | 14 | 02-24-2016 02:37 PM |
