Drives: FRS
So I just made my last payment and hit 50,000 miles, what's gonna be my first repair?
Had my FR-S for 5 years and just crossed 50,000 miles and made my final payment. Never had a check engine light or any of that so my question is for those who have more mileage than me, what should I prepare to repair first? Clutch, Brakes what was your first repair?
#2 | |
http://www.ft86club.com/forums/showthread.php?t=98730 I know for me I will surely be replacing the auto trans fluid, diff fluid and coolant "early" at around 50k
#3 | |
Proud of BOXER
Drives: Subaru Boxer
OP, I like your username!
#4 |
Drives: Asphalt FR-S MT
Sub‘ d
So did I. I hit 50,000 today. 5 years old. I replaced an ignition coil under warranty with a week of warranty left. Just in time. I am also curious what the future might hold. Edit. Although I do have the open flash header, which has not been ceramic coated or wrapped. So the excessive heat was most likely the culprit |
#5 |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
I'm about to cross 50k too. Don't jinx me. Probably clutch kit and clutch release bearing.
Or spark plugs, regular maintenance I think at 60k.
NARFALICIOUS
Noob Poster 1988 | 2016 |
#6 |
Congratulations on getting your car paid off...
And a trouble free 50,000 miles. Oh, from what I read on this forum, I'd guess the TOB would be the first item to need attention, figuring you have already replaced the tires. humfrz |
#7 |
Famous Potatoes
Drives: '15 ultramarine
Just drive it and save your money. Do maintenance per schedule, and fix things if they break.
| The Following User Says Thank You to Sapphireho For This Useful Post: | Tcoat (07-18-2018) |
#8 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
I have almost 3x the mileage as you and the only repair I've done that isn't a regular maintenance item (brakes, spark plugs, etc) was the TOB at 70k. Mine is an early 2013 model and I've done around 16 track days with it.
#9 |
Senior gif poster
Drives: 2013 Asphalt FRS
TOB and might as well get a new clutch kit while your at it. Also good idea to consider everything on the 60k service checklist
#10 | |
Country Boy 4 Life
I would replace your AT fluid before 50k. My car was shifting really hard, so I got mine done at 43k and 73k. If you drive hard, you will notice a difference. OP, besides regular maintenance, I have not really fixed anything besides replacing coil pack #1 when it went out recently. I am at 75K. I did take the opportunity to upgrade my pads and rotors when they needed replaced.
I LIKE TIRES! |
#11 |
Drives: 2014 BRZ Limited
I had my first repair at 65,000 miles. It was an engine replacement when the oil pump gear came apart, starved the engine of oil, spun two bearings and wrecked one of the heads.
Sleep well tonight. |
| The Following User Says Thank You to extrashaky For This Useful Post: | DandoX (07-18-2018) |
#12 |
Since it is paid off, I would start working on your 401K.
| The Following User Says Thank You to Grady For This Useful Post: | Vic4uf (07-18-2018) |
#13 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#14 |
Drives: '13 FRS - STX
Spark Plugs
Unless you're launching hard or slipping the clutch in traffic/uphill every day the clutch should be fine. 72k on mine and it might be nearing the end of its life but I beat it up on a regular basis. |
| News today: 750 Miles driven by repair shop | gily25 | Other Vehicles & General Automotive Discussions | 3 | 09-19-2013 05:30 PM |
| haven't even made the first payment | Gixxersixxerman | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 10-03-2012 02:45 AM |
| Down Payment? | Jeong | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 09-08-2012 12:25 AM |
| Down payment help | Yeti | BRZ First-Gen (2012+) — General Topics | 10 | 08-11-2012 12:40 PM |
| A first for me, my payment went down! | terrypm | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-05-2012 06:14 PM |
