#15 | |
Drives: BR86
Oil Pressure Issues
I hope for everyones sake you're wrong & that's it's a hit/miss issue associated with production. It would be a horrible & expensive nightmare to have an engine blow because of Subaru quality &/or design. Having said that my cars @50K miles is purring just fine & I always use TGMO 0W20, but I always dump it every 4,600miles max if not sooner. And my Blitz oil pressure & temp gauge always reads 15psi/1000rpm or more which seems quite healthy to me. |
#16 |
Drives: 2013 FRS
Since I’ve relied on this forum and videos on youTube by MRT Performance to learn about the FRS/86/BRZ, I’d like to pass on some info. Since reading this thread about bearing issues I reached out to MRT in Australia. (I wish they’d come to the states) - Anyway, they don’t see too many failed, certainty not randomly and failure is more in line with mods, bad tune and lack of maintenance. -
MRT did a great video about connecting rod failure. Bottom line is that as much as Toyota/Subaru push these cars as buildable sportscars, you have to seriously watch your mods and maintenance as they are really temperamental and prone to an early death if pushed. Not my idea of building a sports car but it is what it is. Looking at Subaru and all of its engines, they have had their share of problems and seem to have a serious life expectancy issue with some. Some last forever if maintained to the letter, maybe not. Subbie engines appear to be a throw of the dice especially if you get on them a bit too much or push the mods. Since I’m old school with my oil changes, every 3k, I should be good with that much. Overall the FRS/BRZ/86 is a great platform. It would’ve been nice if Toyota/ Subaru would’ve put a more bomb proof buildable engine into an otherwise fantastic car. |
| The Following User Says Thank You to EddieZ2 For This Useful Post: | humfrz (07-13-2018) |
#17 |
Drives: Track preped NA FRS
I had my engine opened to do some headwork (headgasket decided to retire itself from duty at the track). My car is at around 50k miles and is driven at the track every 2 weeks and has been for the last 3 years. (2013 model). The engine was in surprisingly good health, head gasket aside. I do have only NA mods (exhaust, intake tube and snorkel and tune) as my only power mods and run a koyo rad along with an oil cooler (air to oil) in front of it. I also change my oil every 2 or 3 track days max (so around once per month). It seems so far that maintenance has paid off. I might make a complete compendium when the engine dies for real and I take it in for rebuild and document the state of the interals and what seemed to fail.
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Pat (07-13-2018) |
#18 | |
My criteria has been met by my 2013 FR-S …. ![]() Everyone happy fer me …. ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Sapphireho (07-13-2018) |
#19 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Icecreamtruk (07-13-2018), Sapphireho (07-13-2018) |
#20 |
| The Following User Says Thank You to ermax For This Useful Post: | Tcoat (07-13-2018) |
#21 |
#22 |
Huge E85 fan!
Drives: 2016 Scion FRS
I have a dedicated oil gauge on my car. My old engine (RIP) never had good pressure when heated up. I was nervous to see under 5psi when at idle. The engine in it now (for the time being anyway) is a 13 and the oil pressure gets as low as 5psi but never less. This has always seemed odd to me. The old engine also used a little oil (about a quart every 4000-5000 miles) and the catch can would get about a shot glass full of oil every 1000 miles (I don't know about the 13 engine). I don't known why engine would be different from another, but there it is.
#23 | |
I plan on getting a gauge at some point but I want to get one that I can interface with my Raspberry Pi so I can have an intelligent warning light where I take into account RPM and oil temp rather than some static number. My plan is to connect the RPi to the reverse camera input on the OEM head unit and then rewire the reverse line to my RPi. Then if I ever want to display a warning I simply trip the reverse signal and then it will display on the head unit. Here is the guage (sending unit) I was looking at: https://www.amazon.com/dp/B00RCPDPRQ...v_ov_lig_dp_it Problem is the RPi doesn't have analog input so I need to look into an analog to digital converter or use an Arduino instead of an RPi. |
| The Following User Says Thank You to ermax For This Useful Post: | guybo (07-14-2018) |
#25 | |
Drives: 2013 FRS
#26 | |
Service manual:
#27 |
#28 | |
How low does the oil pressure in this engine have to go, at idle, before the engine suffers damage? Hell, engines have ran for years with the rod bearings just being splashed on. Hey, it's Friday night ![]() humfrz |
| Stock Motor is Toast (Spun Rod Bearing) | DFW-FRS | Issues | Warranty | Recalls / TSB | 78 | 02-13-2018 11:56 AM |
| FS: 2013 FA20 engine w/spun bearing | Bullnettles | Engine, Exhaust, Bolt-Ons | 9 | 04-05-2017 06:39 PM |
| Engine failure - Spun rod bearing TWICE | dinoniel | Issues | Warranty | Recalls / TSB | 38 | 11-07-2016 01:17 PM |
| Spun Rod Bearing #4 | KE70 | Issues | Warranty | Recalls / TSB | 13 | 07-05-2016 03:17 PM |
| Likely hood of a spun bearing | aquaman | Engine, Exhaust, Transmission | 14 | 02-24-2016 01:37 PM |
