Old 07-13-2018, 02:35 PM   #1
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
2017+ Vertical JDM/STI DRL Install Help
About a year ago I saw a post here about the Japanese instructions for these daytime running lights but I can't seem to find it now.
So I need help finding where to connect parts of the provided harnesses.
The first harness I can't seem to find where it connects is the one coming from on/off button.
Here is a close up of the connector
Where does this 2nd harness connect to
I'm not really finding a proper place for them under the drivers side dash shown here
Finally there is a Y shaped harness that connects the 2 lights in the bumper to somewhere in the engine bay... where is that somewhere located?
Here is the that harness
and here a close up of the connector
TachyonBomb is offline   Reply With Quote
Old 07-16-2018, 03:51 PM   #2
johan
Drives: '14 981CS, '99 NB1
USDM cars have different body harnesses, you won't find the right connectors.
The only harness I used from that kit is the one that plugs into the two lights. I cut the connector off that you are holding in that last picture and crimped on female spade connectors. I then used T tap connectors on the OEM boomerang wires on the driver side headlight. Worked great.
You'll have to use a multimeter to figure out which wires are which. I don't have my BRZ anymore so I can't look for you.
johan is offline   Reply With Quote
The Following 2 Users Say Thank You to johan For This Useful Post:
Busybee (06-19-2019), TachyonBomb (07-16-2018)
Old 07-16-2018, 04:45 PM   #3
spike021
spike021's Avatar
Aw man, what happened to it?
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 07-16-2018, 07:52 PM   #4
johan
Sold, picked up a '14 981CS over the weekend.
The Following 4 Users Say Thank You to johan For This Useful Post:
Elliotw (07-17-2018), Irace86.2.0 (07-17-2018), spike021 (07-17-2018), TachyonBomb (07-16-2018)
Old 07-17-2018, 02:12 AM   #5
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Sad but awesome at the same time.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
johan (07-17-2018)
Old 04-25-2019, 01:57 PM   #6
csol
Guys I'm in the same boat. No clue where the hell that connector plugs into.
I have the instructions from japan if anyone wants to help
csol is offline   Reply With Quote
The Following User Says Thank You to csol For This Useful Post:
Old 04-25-2019, 02:00 PM   #7
Grady
Grady's Avatar
Read post right below the original.
Old 04-25-2019, 11:25 PM   #8
csol
I did some of my own research with a multimeter and test pen
Going to run 2 cables throught drivers side grommet on the firewall. (RHD) those two wires then connect to one of the plugs.
The rest is plug and play it seems.
Will post an update for anyone in the future that wants to do it the proper way.
Busybee (11-29-2019)
Old 04-29-2019, 08:34 PM   #9
TachyonBomb
Forget the harness, I just used the on/off switch and connected it to an unused fuse under the dash which connect to the lights. it was a lot easier that way.
On 8/20/19 Works Motorsport have sent me their first payment of $450. Only 5 more payments to go.
Follow what happened here: http://www.ft86club.com/forums/showt...96#post3213496
Old 06-19-2019, 12:27 PM   #10
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Hi Csol,
Di you cut or customize any of the original harness? Please, can you share some pictures or an update how to properly install it?
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 06-23-2019, 06:24 PM   #11
csol
Originally Posted by Busybee View Post
Hi Csol,
Thanks
Sure I did the most perfect install you can have.
Shame on @ft86speedfactory for not going to any effort to get the install instructions.
Got access to the Subaru jap internal accessory install manual.
Busybee (06-26-2019)
Old 06-26-2019, 02:31 AM   #12
Busybee
Busybee's Avatar
Great! Appreciate it?
Do you have more pictures or a write up That you can share?
I sent you a message with some questions?
Would be also great if you can share the installation guide. Thanks
Old 11-29-2019, 08:13 PM   #13
Busybee
Busybee's Avatar
Please, can you share some of the installation details and the Japanese installation guide you have in the pictures?
Thanks
2017+ Bumper Vertical DRLs Irace86.2.0 Cosmetic Modification (Interior/Exterior/Lighting) 33 11-29-2019 08:17 PM
DIY - Vertical Door Install 2013 FRS UF Key Master DIY (Do-It-Yourself) Guides 69 08-11-2018 02:52 AM
Any guide for install this Badge in a new 86 2017? reynierpm Cosmetic Modification (Interior/Exterior/Lighting) 6 08-30-2017 03:05 PM
2017 BRZ Install Kenwood DNX893S 007BRZ Electronics | Audio | NAV | Infotainment 1 08-10-2017 04:40 AM
2017 BRZ and Perrin Oil Cooler Install JSube Tracking / Autocross / HPDE / Drifting 18 04-29-2017 08:49 AM
