Old 07-11-2018, 06:12 PM   #1
Ernest72
Opinions on BBKs
So my 16 BRZ is a DD and the stock brakes are perfect. In fact I barely even use my brakes on my 78 mile round trip commute. So there is no need for me to upgrade for performance.
But I got new wheels (pro race 1.2 in anthracite gloss) and a BBK would look so good front and rear.
So looking for opinions on which way to go, 4pot/2pots, used STI brembos, Other bbks. Obvious I do not want to break the bank pun intended.
No tracking or even auto x and I live in NY so dust boots are probably a must.
Yes I have searched most kits, just want to see what others would do.
Old 07-11-2018, 07:56 PM   #2
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I suggest you look into getting the OEM performance pack brakes if you are in it for the looks. They will be street friendly and require minimal upkeep and work correctly with the car and no worries about daily driving on them although I imagine they will be a bit more expensive than other options.
Lynxis is offline   Reply With Quote
The Following 3 Users Say Thank You to Lynxis For This Useful Post:
new2subaru (07-11-2018), strat61caster (07-11-2018), Tristor (07-12-2018)
Old 07-11-2018, 09:12 PM   #3
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Since it is mainly for looks I'd pick whatever kit appeals to you the most as long it is made for the car and by a reputable manufacturer.
In terms of feedback, even though you want it for looks, I've beat the hell out of the basic 328mm Stoptech kit (it was around $1800 for the fronts) on the track for the past three years and it is still in great shape. I've had the basic Brembo kits on other cars they are excellent as you'd expect.
For more budge-friendly kits take a look at Willwood (caveat: I wouldn't use their stuff for the track even though others do. For street, no problem).
Sleepless is offline   Reply With Quote
Old 07-11-2018, 11:32 PM   #4
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
You should just get fancy rotors, they'll look cool and that's all you're going for.
There are brackets you can use to get bigger rotors (at least in the front) and reuse the stock calipers (way cheaper than a real BBK).
I don't understand cosmetic mods (especially on performance parts), but whatever floats your boat. You should spend the money on seat time at a track or doing autox, you'll enjoy it more.
You could do a full season of autocross for less than the cost of a cheap BBK, or 3-4 trackdays.
14stu is offline   Reply With Quote
Old 07-11-2018, 11:49 PM   #5
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
There are plenty of less expensive options, but I will throw this option out there:
http://www.ft86club.com/forums/showthread.php?t=119701
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 07-12-2018, 12:39 AM   #6
StraightOuttaCanadaEh
Wes
Yeah I agree, I keep getting compliments on the car but whenever I look at those calipers, I cringe. But for some reason every kit I look at only has the fronts? Following this thread with interest cause I also wanna get something that looks good. When I go FI, in the future, it'll come in handy as well.
Instagram: @gt86ws
Old 07-12-2018, 12:51 AM   #7
14stu
14stu's Avatar
The fronts do almost all the braking work, there is no reason to upgrade the rears. The AP Sprint kit is what I run and I love mine. If you are looking for performance that's the one I'd recommend without hesitation.
Old 07-12-2018, 02:26 AM   #8
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Do Not have a BBK myself, but I put braided lines all round, plus better brake fluid and new front discs and pads.
For me this made a big difference and was waaaaaaay cheaper than a bbk.
If money isn’t an object I believe the AP racing kit is amazing.
I like driving!
86 South Africa is offline   Reply With Quote
Old 07-12-2018, 03:04 AM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
Buying a BBK just for looks?
At least you are willing to admit it.
I painted my calipers and since added perfomance is no biggie here why not just do that? There are guys out there that can do it for you I'm sure.
And if that's not enough just add drilled rotors. Slotted might accelerate pad wear too much.
A lot less costly. Buy yourself a nice watch with the money you save. That is blng that is functional.
Your welcome!
Old 07-12-2018, 04:21 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Least costly BBK to fill big wheels
spike021 (07-12-2018), SuperTom (07-12-2018)
Old 07-12-2018, 06:37 AM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Dude I have the perfect solution!!!!
https://www.ebay.com/bhp/brembo-look...-caliper-cover
Yep. Your welcome. Way cheaper than an actual bbk.
The Following User Says Thank You to Mr.ac For This Useful Post:
Spuds (07-12-2018)
Old 07-12-2018, 08:15 AM   #12
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Here's an actual budget front brake upgrade:
Wilwood BBK for WRX - Fit to BRZ
https://r.tapatalk.com/shareLink?sha...4&share_type=t
Old 07-12-2018, 12:40 PM   #13
AFRichZC6
AFRichZC6's Avatar
The AP Sprint kit is more of an exception than the rule. It actually shifts brake bias slightly rearward (better balance), and is one of few kits designed to work with the stock rear brakes. The front brakes still have the majority of the brake bias because of weight transfer. I have the same kit, and I also autocross!
Almost every other front-only BBK will shift brake bias forward even more than stock.
The AP Sprint kit is subtle since they're not huge or painted bright red, but they look plenty cool to me. The ricer in me likes the look of BBKs too.
AFRichZC6 is offline   Reply With Quote
The Following User Says Thank You to AFRichZC6 For This Useful Post:
JRitt (08-15-2018)
Old 07-12-2018, 01:29 PM   #14
ls1ac
ls1ac's Avatar
For looks only===paint, see if you like it.
Then covers for a little more bling.
brake bias for cadillac caliper swap and other BBKs sickmint79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 09-26-2016 04:03 PM
to the people with BBKs Dango1 CANADA 2 06-24-2015 10:11 AM
Brembo BBKs Announced oneday Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 06-11-2014 11:51 PM
I need your opinions WatchmaN Cosmetic Modification (Interior/Exterior/Lighting) 25 12-12-2012 01:11 PM
Thoughts on KSport BBKs? scyzer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 10-01-2012 02:08 PM
