Drives: 2013 FR-S 10 series [755]
Tail light, fog light, license plate light not working
The Valenti tail light, 4th brake light, fog light, and the license plate light all suddenly not working.
For the valenti light, the signal, and brake are working. Just the running light not working. For the fog light, the cluster indicator is working but the fog light is not working. For the 4th brake light, when I press the brake, it works, but it wont stay on as running light. License plate light not working. The tail light fuse was blown. Tried my friend fuse and immediately blown as well. What is the problem? I cant drive like this at night. Thanks.... |
#2 |
I'll venture that you have a short somewhere in your lighting system ….. daaaa .. me.
Who messed with the lighting system? If it was someone else, I'd take the car back to them and ask them to fix it. If it was you, I'd suggest you start with the last light you messed with and look for a bare wire. humfrz |
#3 |
Are you using the Valenti relay?
#4 | |
My friend were behind me yesterday and told me my tail and license plate were not working and yesterday i realize something is wrong... |
#5 |
#6 | |
What else does the circuit that keeps blowing the fuse control .. ?? You may wish to check the wiring on those items. Bubba says to jump the blown fuse slot with a piece of baling wire …. then look for smoke and/or sparks …. there be the problem area … humfrz |
#7 | |
I checked everything..everything seems ok...I am not a fan of electrical..its a mystery to me...lol |
#8 |
#9 |
#10 |
OK, I suggest you disconnect the hot wire to the tail light that is NOT working. Then put in another fuse. If it doesn't blow … then the short is in the tail light circuit that has blown the fuse.
Then chase that wire back into the harness .. looking for a bare spot. humfrz |
| Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 | nigel-jdmparts | Exterior Parts - Lighting | 14 | 06-23-2015 07:32 AM |
| LH License Plate Light Not getting power | Eazid | Issues | Warranty | Recalls / TSB | 4 | 03-27-2015 02:10 AM |
| **Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** | nigel-jdmparts | Exterior Parts - Lighting | 13 | 04-30-2013 01:14 PM |
| Odd question: License plate light? | Double4Free | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 02-20-2012 09:29 PM |
