Old 06-25-2018, 04:47 PM   #1
Driven Photography
Drives: stock 15 FRS
socal smog legal exhaust
does anyone know which exhaust systems are smog legal in socal. I'm looking for something that adds some performance and has a nice sound to it. price isn't an issue but would rather something on the affordable side. Thanks!
Driven Photography is offline   Reply With Quote
Old 06-25-2018, 04:57 PM   #2
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
All exhausts are smog legal. its only the front pipe and the header that you cant change if you want to stay smog legal
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 06-25-2018, 05:30 PM   #3
Driven Photography
Thanks!
Old 06-25-2018, 08:10 PM   #4
Hi Driven Photography.
About the only way to significantly increase power by modifying the exhaust, is to replace the header with one that doesn't have a cat. Therein lies the problem with staying smog legal in CA.
Now, you can change the cat back or axle back portions of the exhaust system and get some cool sounds, but no significant power gains.
The "simplest" way get some sounds and a small increase in power is go with a cat or axle back system, a freer flowing air filter and a tune (optional).
Old 06-25-2018, 10:03 PM   #5
playniceringlands
Drives: 2017 BRZ
Due to the recent increase in ticketing of modified cars in Socal, it might be better to avoid the headache of being sent to the state referee. Cat-back FTW
playniceringlands is offline   Reply With Quote
Old 06-25-2018, 10:28 PM   #6
Thaeyo
Thaeyo's Avatar
+1. Also, be mindful that some exhaust systems are loud and they'll ticket you for excessive noise. CHP can also ding you with Ref too if they're in a bad mood as well
Thaeyo is offline   Reply With Quote
Old 06-25-2018, 11:18 PM   #7
CSG Mike
CSG Mike's Avatar
All catback exhausts are *smog* legal, but may not be *sound level* legal.
Old 06-25-2018, 11:22 PM   #8
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Just get the loudest catback
MS, CSCS, TSAC-F, CPT
Old 06-25-2018, 11:37 PM   #9
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Just gut the cat so you have the appearance of legal. 90% the power gain 0% the cost.
Old 06-26-2018, 12:34 AM   #10
Thaeyo
Thaeyo's Avatar
That won't save you from the Smog check points, sounds dumb, but its a thing. :/
Old 06-26-2018, 01:18 AM   #11
Brink
Drives: 2017 BRZ
Originally Posted by Xxyion View Post
All catback exhausts are smog legal. its only the front pipe and the header that you cant change if you want to stay smog legal
FTFY
Brink is offline   Reply With Quote
Old 06-27-2018, 02:14 AM   #12
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
The only suggestion i have is try to find a high flow catted header that you can fit the stock heat shield onto with little to no modification.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 06-27-2018, 12:35 PM   #13
Paul86Ski
Drives: Stockish 2018 Toyota 86
You can say no to the smog check points.
And even if you fail the smog test, there aren't any consequences.
https://www.bar.ca.gov/Consumer/Road...n_Program.html
Paul86Ski is offline   Reply With Quote
Old 06-27-2018, 02:17 PM   #14
CSG Mike
CSG Mike's Avatar
There are no *immediate* consequences, but there are many stories of cars getting a ticket just down the street after turning it down. I can neither confirm nor deny; you know how the internet is with these things....
WORKS Stage 2 Turbo Kit - Now CARB Compliant/SMOG Legal WORKS Forced Induction 415 10-16-2021 05:55 PM
Borrow/rent stock BRZ intake assembly for Socal smog nickzue Southern California 8 09-26-2017 08:21 PM
WORKS Stage 2 Turbo Kit - Official Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 89 01-13-2017 04:41 PM
CARB Compliant WORKS Turbo Kits - Now Available! 50-State Smog Legal! WORKS Forced Induction 47 01-13-2017 04:40 PM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
