Old 06-20-2018, 01:59 AM   #1
PVLFD
Question Need help identifying this metal sound
Need help identifying this metal sound. It happens every time the car has been parked for some time and I get out of the driveway and turn left. My guess is most of the weight shifts to the right so it makes this sound. Then also when I press the brake the first time it does a metal clanking sound. In this video I do it mostly on the driveway by going back and forth turning the steering wheel. There is no noise whatsoever when I drive on a road or go over bumps. I also took it to the dealer since I have extended warranty but they couldn't find anything (as expected). I recently changed my shocks/springs (the noise was there before) and all the bolts that I removed were re-tightened to the spec.
Here is a video:
PVLFD is offline   Reply With Quote
Old 06-20-2018, 02:29 AM   #2
Good video!
Are you referring to the metallic/crunch/click -ie type of sounds?
Welp, back-in-the-day, Idda guessed it was a rock in the hubcap …. now, THAT ought to give you an idea of how much help I'm gonna be ..
Seriously, does it do it when you start off, if you hadn't set the parking/emergency brake?
Can you isolate which wheel(s) are making the sound?
I suspect the sound is coming from the brake(s).. fer sure.
Old 06-20-2018, 02:35 AM   #3
PVLFD
Good video!
Yes, the metallic click or whatever that sound is called.
I haven't tried without the hand break, will give that a try but doubt that's it.
My guess it's coming from the passenger side where I mounted the camera.
I also thought it was coming from the brakes but it puzzles me why it's only happening after I make a left turn and then press the brake. I think when I press the brake the weight shifts and that's what making the noise but I have no clue.
I wanted to mount the camera somewhere behind the wheel but couldn't find a spot for it. If nobody can identify this noise I might do it.
The Following User Says Thank You to PVLFD For This Useful Post:
humfrz (06-20-2018)
Old 06-20-2018, 03:02 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Odd indeed.
My first guess is the top nut on the struts.
Endlinks, then sway bar bushings?
Might be better to add another 10-15ft/lbs to your torque wrench
Old 06-21-2018, 12:00 AM   #5
PVLFD
Odd indeed.
The strut has been recently replaced (from 2013 to 2017 parts) and the noise is still there so I doubt that's it.
I guess I can try to tighten the other stuff with extra 10-15 of torque.
Could it be the bearing? But I think that would make the noise every time I steer, like this [ame]https://www.youtube.com/watch?v=LV29cvIFdYk[/ame]
Old 06-21-2018, 02:33 AM   #6
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Wheel bearing? Maybe? Usually that's a fwd problem, or a rear wheel bearing for rwd cars. Maybe your the lucky one in the 10% where it does fail.
A bad wheel bearing is easy to check, just jack up one wheel and check for any noise/wobble while holding at 12 & 6 or 9 & 3 or anywhere in between.
I'm putting my money on the struts just because they have been recently replaced.
Heck it might even be not suspension related. The last guy I read with a clicking sound ended up being a lose heat shield.
Another part I forgot is the ball joints.
Old 06-21-2018, 01:48 PM   #7
highway7
Drives: FRS 2013
For me, it was the brake pads not sliding properly. I took out the pads and the sliders, cleaned the old grease, regreased, and the noise went away
highway7 is offline   Reply With Quote
Old 06-28-2018, 12:54 PM   #8
PVLFD
Wouldn't it make this noise every time you press the brake then?
metal on metal sound when releasing the clutch MyNave Engine, Exhaust, Transmission 7 04-18-2018 01:00 AM
Metal scraping sound at idle brzzy Issues | Warranty | Recalls / TSB 38 11-24-2017 06:12 PM
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 11:09 AM
Help identifying this engine sound (injectors?) DJLtoronto Engine, Exhaust, Transmission 7 04-20-2014 10:44 AM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 05:37 AM
