Old 06-19-2018, 11:16 PM   #1
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
Lug nuts for STI wheels
Just got a set of STI wheels. I checked the lug nut hole and noticed that the lug nut seat (60 degree conical type) is very shallow. I have Rays lug nuts at home and tested fit it on the wheel and found that it barely seated on the wheel.
My question is can I use normal 60 degree conical type lugnut such as Rays, Kyoei and other similar tuner lugnuts? Or do i have to use OEM lugnut?
Also, from my search, I found that Magard spline drive lug not is also compatible as it has shallow 60 degree conical type.
Do you have any recommendations or experiences to share?
Spec C Wannabe is offline   Reply With Quote
The Following User Says Thank You to Spec C Wannabe For This Useful Post:
Busybee (11-20-2021)
Old 06-20-2018, 08:30 AM   #2
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I bought the gorilla tuner lug nut in blue and they work fine. I'm guessing any tuner style lug nut that is conical will fit.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
JohnJuan (06-22-2018)
Which lug nuts for XXR wheels? Nickel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-23-2016 03:50 AM
Lug nuts for steel wheels nmastereal Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 11-03-2014 10:03 PM
OEM lug nuts with aftermarket wheels? srtblake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-18-2014 04:48 PM
Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com Josh@FullyBolted.com Wheels and Tires 1 06-25-2012 03:04 PM
