View Poll Results: Do you have the described AT issues?
Yes, but I've ignored them 41 34.17%
Yes, TSB fixed it 14 11.67%
Yes, dealer fix did not help 12 10.00%
No everything is fine 53 44.17%
Voters: 120. You may not vote on this poll
Old 06-19-2018, 12:15 PM   #267
Richard_BRZ
Richard_BRZ's Avatar
Drives: 2017 WRB Subaru BRZ Sport-Tech
Originally Posted by FRSBRZGT86FAN View Post
@Richard_BRZ
According to @Cole his dealerships wouldn't play ball as well in Canada
Also if your a 2017 your issue is most likely something else, you really should have the latest TCM update present on the TCM
Thanks! When I cleared my CEL which I received from my header install, the tranny went back to working as it should. Just had a mild panic attack lol
Richard_BRZ is offline   Reply With Quote
The Following User Says Thank You to Richard_BRZ For This Useful Post:
FRSBRZGT86FAN (06-19-2018)
Old 06-19-2018, 06:49 PM   #268
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Glad you got it fixed! I noticed if OFT causes a code to be dropped it will do it regardless as well...
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Richard_BRZ (06-19-2018)
Old 02-27-2023, 08:58 AM   #269
brzzzz2019
Drives: 2019 BRZ 6AT
2019 BRZ 6AT
Just wanted to ask if there are any 2019 BRZ owners who experience the same problem? Rough and delay shifting, 1st to 2nd gear notchy, changed atf and diff oil to redline d6 and 75w90. dealership says no tcm update for MY2019.
brzzzz2019 is offline   Reply With Quote
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 12:54 PM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 07:17 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 01:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 04:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
