#841 |
Drives: Peugeot
#842 | |
Drives: Audi A4 B7 2.0T Quattro
That motor controller you made is that open source? Do you recommend any of the shelf controllers? |
#843 |
Drives: Peugeot
#844 |
#845 |
Drives: Peugeot
#846 |
#847 |
Drives: Peugeot
Actually what I got from my setup, which is pretty similar to yours, is that the power used on 0,5 Bar pressure was about 3000-3500W. So in your case of 24V power the top constant consumption theoretically woud be about 150-160A. Probably even a bit less, I admit a better efficiency of my motor controller on lower voltage.
#848 |
APS who sell the motor said that its the competition versjon of the motor and it can handle 30v and reach 70 000rpm, so a 8s lipo pack or something that can get me to around 30v should be ideal.
160A is probably plenty, but I I think I will get a bigger esc just to have some good margins and better cooling. This one looks allright https://alienpowersystem.com/shop/es...t2-car-esc-hv/ Last edited by al3k; 06-19-2018 at 06:37 AM. |
#849 | |
Drives: Peugeot
What KV number for the motor you're considering to use? Last edited by KroozX; 06-19-2018 at 08:28 AM. |
#850 |
#851 |
Drives: blue - Cosworth SC stage 3.0
If the sensor equipped motor isn't much more then yes its would be well worth it as you could then see how fast you manage to achieve
#852 | |
Drives: Peugeot
Right now I'm pretty sad that I haven't ordered a 3200kV version. That would make my build a bit simpler.
#853 | |
most of them ive seen is max 50k rpm
#854 |
I will put a ceramic ballbearing inside the backplate right under the compressor wheel, with a small washer.
This will make the shaft more stable and seal the shaft from the backplate/compressor. Compressor wheel needs to sit exactly 1mm above the edge of the hole, thats also why I want the washer so I can fine adjust the heigth just incase some tolerances is off after the shaft as been custom machined |
| Tags |
| hairdyerperformance, only pulls hard one gear |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 07:42 PM |
| DUP THREAD MODZ PLZ DELETE KTHX | SloS14 | Forced Induction | 0 | 07-09-2013 06:41 PM |
| Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 03:47 PM |
| Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 03:16 PM |
| WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 10:20 PM |
