Old 06-17-2018, 12:48 AM   #1
kuyumoy
Drives: scion frs
Vibration under the engine from around 3kph to 0
so I noticed a vibration under my car (mainly under the engine) everytime Im letting the car to stop in neutral (no brake pedal pressed). the vibration starts when the speed goes down to like 3kph until its 0kph then it goes away when the car is in a complete stop. the vibration is feel like when you slightly let go clutch a bit quick on the 1st gear that it shakes the car. (I suspect the drive shaft but maybe I am wrong).
kuyumoy is offline   Reply With Quote
Old 06-17-2018, 12:52 AM   #2
DeltaEcho
DeltaEcho's Avatar
Drives: 17BRZ Limited TS
Sounds normal...
But to be sure, check all your fitments and connections. Make sure there are no leaks in the engine.
Do that first. Odds are if you found a leak or something disconnected, there's your issue
Sent from my G8142 using Tapatalk
DeltaEcho is offline   Reply With Quote
Old 06-17-2018, 12:57 AM   #3
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Are the engine rpms dropping?
murdoc is offline   Reply With Quote
Old 06-17-2018, 01:24 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Ok, let's start with the unanswered stuff first.
What did you do to your car before it started?
Did you hit something on the road? Deep pot hole? Jumped a curb?
Old 06-17-2018, 10:05 PM   #5
kuyumoy
Drives: scion frs
okay so I went under the car to check if there's any leaking parts but everything looks good to me
* and before I noticed that, I passed by a really deep train tracks and feel the heavy bounce of my front and thats what I only remember before noticing that problem
* and right now I can hear a humming sounds (increasing when speeding) under my rear wheel, that's after I changed my rear diff fluid with motul 300
Old 06-17-2018, 10:07 PM   #6
kuyumoy
Drives: scion frs
engine rpm is not dropping and seems to be a fine normal idle every starts
Old 06-17-2018, 10:09 PM   #7
kuyumoy
Drives: scion frs
Old 06-18-2018, 08:59 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
Have you checked your tyre pressures?
1974 TA22 Celica
2013 86 GT
Old 06-18-2018, 10:06 PM   #9
CoolHandMoss
Drives: 2013 FRS
I've noticed my car doing something similar since I started using the air conditioner this year. This is my first year with the car so it may be standard behavior for these cars with the a/c on. My car does more of an audible rattle rather than a shake, but it sounds similar and under similar conditions. Point is, if this is happening with the a/c on, see if it also happens with the a/c off. For me, realizing the relationship put it out of mind that it might be an actual issue.
CoolHandMoss is offline   Reply With Quote
Old 06-19-2018, 01:10 AM   #10
kuyumoy
Drives: scion frs
I'm hearing it with the a/c off and even if the car is off and I tried to push it forward, I can feel the vibration under the engine bay ( that feels like a gear head that missed its thread to the other gear head)
Old 06-19-2018, 02:04 PM   #11
WNDSRFR
Drives: FR-S,GTI
I think I know you're what you're talking about. Whenever I come to a stop usually at a light. I step on the brake and slow down to maybe 1 or 2 mph and with the brake off, when coasting to a stop, I feel a vibration. It feels like the ABS pulsing. Until I come to a complete stop. It doesn't happen all the time, but pretty often. It's done it since the car was new (has over 130,000 miles now) so I don't consider it a problem but it is a curiosity.
Old 06-19-2018, 10:58 PM   #12
kuyumoy
Drives: scion frs
yeah it does happen everytime if I roll from around 3kph-0 slowly without pressing the brake but if I press the brake a little hard to sudden stop then it doesnt feel anything ( maybe because the rotating thing suddenly stop thats why it doesnt feel the vibration)
*Anyways I'll take a note on what you said and thanks for the response 👍🏼
Old 06-19-2018, 11:50 PM   #13
Maybe you have a damaged tire. Do you get a little wobble in your steering wheel?
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 08:58 AM
engine rattle/vibration sound @ coldstart beat1 Issues | Warranty | Recalls / TSB 7 04-12-2017 10:59 AM
Engine rattling/vibration happening between 3k - 3.3k Boofneenee Issues | Warranty | Recalls / TSB 4 05-18-2014 03:34 PM
uneven engine vibration at idle whtchocla7e Issues | Warranty | Recalls / TSB 17 08-07-2013 10:21 PM
