Old 06-09-2018, 02:16 AM   #71
extrashaky
Drives: 2014 BRZ Limited
It looks legit.
To me it looks like a disaster waiting to happen when that thing springs a leak inside the passenger compartment.
The Following User Says Thank You to extrashaky For This Useful Post:
FRSBRZGT86FAN (06-10-2018)
Old 06-09-2018, 02:19 AM   #72
It's good to 300 psi. Send it.
Old 06-10-2018, 01:54 AM   #73
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
No diy given. The guy that posted it got banned before he could go into detail. He was a bit odd anyway.
Who knows. He was the kind of guy that would drive around with two holes where his exhaust tips should be and no back up lights. You know the type.
For sure that guy ended up being full of it, he's using one of those connectors you use for a garden hose to mate the gauge to his tubing -_-
Old 06-10-2018, 01:58 AM   #74
FRSBRZGT86FAN
I'll reply here regardless. I have a pretty special oil cooler setup. People would consider it oversized but I can manually adjust the flow after the thermostat.
Based on specs published in the service manual, the important number to watch for is the target maximum oil pressure of around 70-75 PSI. 0W20 is fine for me if I keep it under 185 F. I haven't experimented with other viscosities because I like the fuel efficiency benefit.
A couple of the local guys have beaten the piss out of their engines with no oil cooler and are still running strong. I think engine longevity is mostly a numbers game with respect to build quality and manufacturing tolerances.
I suggest getting the pressure gauge first so you can watch it and make informed choices. For instance, you will notice how high the pressure is when it's cold. It's a struggle for me to keep it under 120 PSI for the first few minutes. 140 PSI is where it bypasses to protect gasket and o-ring seals, and the pump. Keep that in mind as you play with viscosity.
@Dezoris also known as savagegeese on youtube had the best post for oil pressures if your curious with them compared to viscosity he used:
http://www.ft86club.com/forums/showp...&postcount=305
He was in the first large group of people to be doing extensive testing to his car for track use and vortech supercharging, it's worth the read and video watch.
Old 06-10-2018, 02:42 AM   #75
Yeah, I've been through all of the early stuff. None of those guys controlled temperature with any rigor. That's why I built my custom setup.
Old 06-10-2018, 04:58 PM   #76
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Question
Those are very good points and will be taken seriously. My car is a '14 with a 1/14 build so I'm wondering if anything changed between the first '13 builds and mine. I didn't give it a lot of thought before buying, so now I better find out what I have and if, for instance, oiling mods and a tune are in order.
Qwimby1 is offline   Reply With Quote
The Following User Says Thank You to Qwimby1 For This Useful Post:
Ultramaroon (06-10-2018)
Auto launch blows! feldy Engine, Exhaust, Transmission 83 04-14-2017 10:42 AM
Dr. Destructo blows a rocker apart Element Tuning Engine, Exhaust, Transmission 82 12-04-2015 03:00 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
This blows... finch1750 Electronics | Audio | NAV | Infotainment 19 06-21-2012 12:03 PM
