#309 | |
Almost Every OE car on earth runs a cat before the turbo.
How about its brother car the Imprezza WRX. Cat in the uppipe. The catalytic converters these days do not degrade for hundreds of thousands of miles. Theres no concern here from my perspective. Quote:
#310 |
I don't understand the concern w/ the flooding. Are you thinking it will suck in water. Explode? what?
#311 |
Drives: 2013 Firestorm FR-S 6MT
Sub'd for the awesomeness that is to come....
2013 Firestorm 6MT
2005 Corolla XRS |
| The Following User Says Thank You to clevrname For This Useful Post: | Exhaust (07-11-2012) |
#313 | |
Drives: turbo scion tc
| The Following User Says Thank You to slow_frs For This Useful Post: | ImAwesome (07-11-2012) |
#314 |
Drives: Not Yet
#315 |
Drives: 99' M3, 13' SWP Brz
| The Following User Says Thank You to ImAwesome For This Useful Post: | armythug (07-14-2012) |
#316 |
Drives: Scion FR-S
#317 |
No. The car will bottom out on the front subframe first before the turbo will be affected. You will have to do something real crazy to get to it.
Don |
#318 |
My car is also 2.5" lower than stock. I've maxed the Tein Flex's as low as they will go. I've looked at it on the ground and I still don't suspect an issue.
#319 |
Filter location is not permanent, but this is approximately where it is going. Still working on the details with the maf location, so I haven't made any brackets yet. Most likely will stay right here and have brackets fixing to the intake manifold rear.
I've switched to 3" intake piping and it makes the fitment alot trickier. I wanted to beat me head against the wall when I was making it. The car made me bleed a few times as well
| The Following 9 Users Say Thank You to Don@Accelerated For This Useful Post: | Chewie4299 (07-13-2012), civicdrivr (07-12-2012), cobrabyte (07-11-2012), Guff (07-12-2012), koyv90 (07-12-2012), slaxx (07-11-2012), Spaceywilly (07-11-2012), SVTSHC (07-18-2012), Symbiont (07-11-2012) |
#320 |
The maf the same used on most new Toyota and Lexus models it is capable of withstanding a blow-tru maf setup I say place it in the charge pipe some where before the 90 to the throttle body
#321 |
Drives: 13' WRX
Anxiously Awaiting Vids
I have been following this thread since it began and get more excited every day. Also been following the HKS Supercharger and it does not look promising. I plan on buying this eventually, just wanna see dyno and other people test it first haha.
#322 | |
Drives: Not Yet
It just that Im use to seeing turbos in the engine bay instead under the car. |
| Accelerated Performance 2013 BRZ Intake Dyno Testing Video | Don@Accelerated | Engine, Exhaust, Transmission | 109 | 05-17-2013 12:24 PM |
| Accelerated Performance 2013 BRZ Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 135 | 09-04-2012 12:24 AM |
| Accelerated Performance 2013 BRZ/FRS Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 24 | 07-07-2012 08:05 AM |
| Hello from Accelerated Performance! | Don@Accelerated | Announcements, Contests, Giveaways | 5 | 07-04-2012 09:14 PM |
