#463 | |
Drives: 2017 WRB Subaru BRZ Sport-Tech
I know how to flip the orientation on the older tablets, but if that option still exists it’s not in the same menu location with V2 tablet. Unless you know something I don’t?! Sent from my iPhone using Tapatalk |
#464 |
Drives: FT86
Nothing specisl needed just download the v4 tune for your car load to oft and flash
http://support.openflashtablet.com/support/home Go to link above type in your ecu calid like ZA1JK00C or whatever yours is download tunes upload to oft woth openflashmanager and flash car |
| The Following User Says Thank You to steve99 For This Useful Post: | neilvosko (06-02-2018) |
#465 |
Drives: 17 Series Yellow BRZ
My fueling was off a good deal on the 2017 K00C tune. Had to scale my MAF to get AFR to match the commanded AFR. I was running a but lean in open loop. You all might want to do a log and compare.
I'm also having to pull a little timing to redulce FLKC. Trying to do it with the IAT compensations. Will report results of that later. |
| The Following User Says Thank You to Jasonb For This Useful Post: | DAEMANO (06-02-2018) |
#466 | |
Drives: Hyper Blue BRZ
Hi Steve,
quick sanity check, you uploaded a def file A01G in the original post that has additional tables compared to OTS 4.0 def, like Engine load, etc. so can we use your Def file instead, just change the A01G to our own cal id, ie F00C and make changes to engine loads, MAF scale per wayno, then save the new file and upload via OFT with no issues? basically, using your def file (edited with our own cal ID in txt file) vs the one provided with OFT ? thanks in advance, neil Quote:
#467 | |
Drives: FT86
yes should work just check some tables to make sure all looks ok as per http://www.ft86club.com/forums/showthread.php?t=79152 |
#468 |
Drives: Scion FRS
After flashing to v4 tune on my 18 BRZ, everywhere but the torque dip definitely feels much stronger than stock. The only issue I feel is that the torque dip feels much worse than stock. Has anyone else felt this way? I am running State 1 tune on 94 pump.
#469 |
Drives: 2015 asphalt FRS
Sorry i haven't read most of the new posts, but i have flashed the new tunes and goodness.... I cant believe you guys are doing so much for us. The cold start valve overlap removal and cold start on e85 makes me want to buy a v2 just to say thanks. I am in norcal so we haven't seen much cold weather since i flashed the new updates, but before i couldn't start on first try under 55ish. So far i have been down to 49 and fired right up. Also my neighbors thank you for the valve overlap fix. I tried a couple things but didnt want to get to far out there. I am almost catless (cnt midpipe with tiny HF cat, catless header) and it was a bit obnoxious before. Before the new tunes i had also went back to 91 since i couldnt start half the time. Now im burning corn juice and i almost dont remember until i smell it. I might buy a sticker just to rep. LOL. Sorry to sound so stupid but im pretty happy so far a month into running them.
#470 | |
Drives: FT86
!og wahts going on and post it up here,might be able to see wahts going on |
#471 |
Drives: Scion FRS
#472 |
Drives: brz 2017 hksv2
Personally i would. Try maf scaling with vgi maf scaling tool, and try put higher timings at that rpm/load zone
#473 | |
Drives: WRB 2017 BRZ Limited w/ PP
#474 | |
V4 stage 2+ is much better than v3 on the 2017 manual cars. I feel like v3 basically was just there to turn the check engine light off. V4 makes quite a bit more power and is quite a bit smoother as well. |
#475 |
#476 |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 08:29 AM |
| The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 05:14 PM |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 03:04 PM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 07:29 PM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 04:35 PM |
