Old 08-24-2017, 03:57 AM   #1
Scourge
Agent 86
Drives: 2017 Toyota 86
Talking OEM FR-S/BRZ/86 Suspension Part Numbers
Just thought I'd post some of the OEM part numbers in one thread. Some Toyota/Scion parts will have a Subaru part number too. It'll help someone ID used OEM suspension.
Sources: https://parts.toyota.com and http://parts.subaru.com/
BRZ PART NUMBERS
Front Strut (Right)
2013-14 - 20310CA020, 20310CA021
2015-16 - 20310CA120
2017-17 - 20310CA160 (SACHS), 20310CA220
Front Strut (Left)
2013-14 - 20310CA030, 20310CA031
2015-16 - 20310CA130
2017-17 - 20310CA170 (SACHS), 20310CA230
Front Springs
2013-16 - 20330CA010
2017-17 - 20330CA200
Rear Springs
2013-16 - 20380CA010
2017-17 - 20380CA210
Rear Shocks
2013-14 - 20365CA010, 20365CA011
2015-16 - 20365CA110
2017-17 - 20365CA120 (SACHS), 20365CA210
FR-S/86 PART NUMBERS
Front Strut (Right)
2013-14 - SU00300371 - 20310CA000
2015-16 - SU00305256 - 20310CA100
2017-17 - SU00306792 - 20310CA200
Front Strut (Left)
2013-14 - SU00300372 - 20310CA010
2015-16 - SU00305257 - 20310CA110
2017-17 - SU00306793 - 20310CA210
Front Springs
2013-16 - SU00304144
2017-17 - SU00307193
Rear Springs
2013-16 - SU00304147
2017-17 - SU00307196
Rear Shocks
2013-14 - SU00300382 - 20365CA000
2015-16 - SU00305258 - 20365CA100
2017-17 - SU00306797 - 20365CA200
Scourge is offline   Reply With Quote
The Following 5 Users Say Thank You to Scourge For This Useful Post:
chaoskaze (08-28-2017), Iceman (05-30-2018), LancePower (08-28-2017), pumice (08-09-2018), Vital (08-24-2017)
Old 08-24-2017, 09:56 AM   #2
Vital
Drives: 2015 BRZ
This might be a silly question, but is it possible to use the PP Sachs dampers in the pre MY2017 cars? Or has anyone upgraded their suspension to the PP suspension on their pre 2017 cars? sorry if this has been covered before im just curious
Old 08-24-2017, 10:39 AM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Nope, go for it.
Probably the best bang for buck upgrade to an early car at this point is a set of low mileage '17+ coilovers for a few hundred bucks given the reviews the new cars get.
ineedyourdiddly
Vital (08-24-2017)
Old 08-24-2017, 10:48 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
strat61caster: but how well they will work with older spring rates, or everything including springs and rollbars (IIRC also changed vs older?) should come over?
Old 08-24-2017, 11:05 AM   #5
Vital
Drives: 2015 BRZ
Nope, go for it.
Thats exactly what im thinking. I looked up the price for the Sachs dampers and they really arent too bad. Maybe someone if decides to sell theirs i may for it as i'd like to get RCE yellows so im sure they would pair well together.
Same, id like to know how well the older model springs would work with the Sachs dampers.
Old 08-24-2017, 11:39 AM   #6
strat61caster
Oh, I was under the impression that the question involved using the new springs as well and not just the dampers.
In any case I believe it would be close enough to not be "bad" (or anywhere close to bad) but maybe not as good as possible. I'd say most agree, as far as I can tell almost nobody aftermarket is changing part numbers for dampers (i.e. Koni and Bilstein) or lowering springs (i.e. RCE, Eibach, H&R) as they all say they can be used with whatever chosen spring or damper.
@Vital part of the reason why I suggested it was the new spring rates play a factor in the good reviews the '17+ cars are getting, if you're not going to change springs I would think an aftermarket damper would be more satisfying, but if you can get a good price then I think the '17+ OE is a viable replacement.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Tcoat (08-24-2017), Vital (08-24-2017)
Old 08-24-2017, 01:42 PM   #7
Scourge
Agent 86
Yeah, using old springs with new dampers is sometimes an issue. I have a 2017MY Toyota 86. I ordered a set of Eibach Sportlines and was about to install them until I found out from Eibach themselves said they don't ride great with the 2017 86 struts/shocks (but their Pro-Kit is fine). I ended up getting some used 2015-16 struts/shocks cheap to use on the springs.
I'd also imagine the Sachs setup would feel fine if you used the 2017 BRZ springs and swaybars.
Old 06-29-2018, 05:37 PM   #8
gpvecchi
gpvecchi's Avatar
OK, I finally managed that there is even another part number for Sachs shocks and springs for JDM BRZ STi Sport. Do you know if this specific model is lowered or not?
gpvecchi is online now   Reply With Quote
Old 06-29-2018, 06:49 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, for completeness sake shouldn't also list be updated with swaybar partnumbers in zenki & kouki, as they imho are designed to work with as system with updated spring & damping rates of new shocks/springs? And whatever else might be updated in suspension .. weren't there some bolts too? Or that was in MY2015? Memory is vague ..
OEM Suspension Upgrade Part Numbers - Group N, STI, Bilstein, etc. Createddeleted Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-12-2017 03:49 AM
Part numbers or part diagram? pacemkr Engine, Exhaust, Transmission 6 08-22-2016 01:44 PM
Part Numbers tommy Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2013 04:33 PM
ANyone know these part numbers? J-Money Scion FR-S / Toyota 86 GT86 General Forum 3 04-22-2013 12:37 PM
part numbers Staticfrost BRZ First-Gen (2012+) — General Topics 5 05-29-2012 12:02 PM
