Old 05-29-2018, 05:43 PM   #1
Jamesallen45
Drives: 2013 FRS
2013 FRS Engine Died
My FRS just died on me one morning. I had gone about 2 miles, doin around 25 mph and it shut off. It made a metal clanging noise and I immediately pushed in the clutch, rolled to a stop and tried to start. The starter freely spins but will not engage the flywheel. I only have a few ideas...Battery, starter are good. Not sure why starter will not engage flywheel. Hoping something came loose that would cause starter to be unable to engage. Something shut down the engine. Any thoughts? Catastrophic or something manageable?
Jamesallen45 is offline   Reply With Quote
Old 05-29-2018, 06:51 PM   #2
mrg666
pessimistic skeptic
mrg666's Avatar
Your description sounds like broken rod/rod-bearing, camshaft, or timing chain. Broken timing chain is less likely. I would just get it towed to a reliable shop and diagnosed. Is this stock engine?
The Following User Says Thank You to mrg666 For This Useful Post:
MJones_RB (05-29-2018)
Old 05-29-2018, 10:52 PM   #3
highway7
Drives: FRS 2013
The starter disconnects once the engine is started, so it wouldn't make sense for a starter to be the cause of the to engine shut down. Starter won't start the engine if the engine is seized or internals are destroyed.
How was oil level? Last oil change? Was the temp good? Any sign of overheating? Was car driven hard? Did you miss 3rd?
highway7 is offline   Reply With Quote
Old 05-30-2018, 02:20 AM   #4
Welcome to our forum, there, Jamesallen45 …….
Too bad your FR-S is acting up......
As asked before, do you have any power mods .. ??
If you have a code reader, does the engine show you any codes .. ??
As asked before …… does the engine have oil in the crankcase .. ??
Like said, sounds like it's time to take it to a shop …..
Please keep us posted.
Old 05-30-2018, 03:59 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Oh that does sound good. Anything with a metal crunching then a dead engine is not good.
By the sounds of it could be a broken rod, or cam.
As humfrz said any mods to the engine?
That could point us to what happened.
Old 05-30-2018, 11:05 AM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
That's odd that the starter spins but doesn't engage the flywheel though. I've never heard of something like that happening.
The Following User Says Thank You to Spuds For This Useful Post:
strat61caster (05-30-2018)
Old 05-30-2018, 12:23 PM   #7
KDad2
KDad2's Avatar
Drives: 2013 Raven
Sorry to hear that too. Is your transmission manual or automatic? If it is manual, does it start with the clutch pressed in? Does it stall when you release it?
If all that is good, then perhaps this is an opportunity for an engine swap! I would be considering the same...
KDad2 is offline   Reply With Quote
Old 05-30-2018, 01:08 PM   #8
Ya that is not usually a symptom of a bad bearing or rod. We really need more info instead of just pissing into the wind with guesses.
Ummmmmm see above.
KDad2 (05-30-2018), strat61caster (05-30-2018)
Old 05-30-2018, 01:46 PM   #9
Oh, yes …… that can happen ……. just ask ol @Tcoat …… with all those clunkers he has had in the past, I'm sure that has happened to him …..
Old 05-30-2018, 01:50 PM   #10
Ummmmmm see above.
Yep, we need to hear back from @Jamesallen45 with additional information.
Also, @KDad2 …...have another cup of coffee ……..
KDad2 (05-30-2018)
Old 05-30-2018, 02:10 PM   #11
KDad2
KDad2's Avatar
Drives: 2013 Raven
Sorry guys. Yes, I do need coffee, running on about a few hours of rest and thought I refreshed the page when work stuff happened during my post.
The Following User Says Thank You to KDad2 For This Useful Post:
humfrz (05-30-2018)
Old 05-30-2018, 05:02 PM   #12
You let "work stuff" get in the way of your posting on the forum …..
Talk with @Tcoat ……. he must have a workaround for that …….
Tcoat (05-30-2018)
Old 05-30-2018, 06:06 PM   #13
Easy. Get into a career you like. Slowly grind your way up the ladder. Eventually get to a point where you can get others to do much of the heavy lifting. It only takes about 30 years or so.
And contrary to appearances I get a shit load of work done every day.
g e (06-04-2018), humfrz (05-30-2018)
Old 05-30-2018, 06:44 PM   #14
KDad2
KDad2's Avatar
Drives: 2013 Raven
Keep working for more car parts. Save up to exit my current profession and move on to one I enjoy!
clutch, flywheel, motor died, starter
Sooo..The BRZ died zypher Issues | Warranty | Recalls / TSB 15 08-16-2017 10:31 AM
2017 engine vs 2013 engine DailyDriver86 Engine, Exhaust, Transmission 17 11-09-2016 06:16 PM
I died when I saw this.. Koa Scion FR-S / Toyota 86 GT86 General Forum 71 03-30-2015 11:48 PM
MR2 died, replacement? serialk11r Other Vehicles & General Automotive Discussions 86 03-24-2015 01:12 PM
I just died inside. DIG1992 BRZ Photos, Videos, Wallpapers, Gallery Forum 62 07-02-2012 09:51 PM
