Old 05-28-2018, 09:54 PM   #1
TE51
Drives: 1978 Corolla
Camber specs the same but look off
Hello,
Not sure if this is in the right sub, but I got an alignment last Saturday. I’m running BC coils and I was looking at my car today and the passenger side camber looks a lot less negative than the driver side. I also checked the camber settings on the top hat of the coils and the passenger side looks a lot different than the driver side as well. The sheet I was given back says they’re both set at -1.5 degrees but to doesn’t look like it and I’m also getting a lot of pull to the right, should I take it back to the alignment shop?
TE51 is offline   Reply With Quote
Old 05-29-2018, 12:22 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yes take it back. While the camber might be right the toe maybe way off.
It's not common but sometimes people forget to tighten down bolts. That's my guess on what happened.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (05-31-2018)
SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) Joesurf79 Brakes, Suspension, Chassis 2 01-13-2017 06:03 PM
RS1 Camber Specs Natedawg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-10-2015 11:50 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
