Old 05-28-2018, 05:10 PM   #1
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Memory Saver For Battery Replacement
Hey gang, as we all know our stock Panasonic batteries are pretty weak - and after about 6 years of ownership, I think it's almost about time to replace it for a more powerful & deep-cycle battery (since I run a dash camera).
Now I also want to save all my memory (radio presets, because my radio is apparently wonky - locks me out and none of the codes work... Already dealt with dealer and they sent it in for reflash but still couldn't get the codes)... Have any of you used a method where another power source is plugged in while changing out the old battery? (Through OBD2, or cigarette lighter?)
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 05-29-2018, 02:08 AM   #2
firekat
Drives: 2018 Subaru BRZ tS
Panasonic batteries weak? I just replaced the battery on my 2007 FJ Cruiser, that I actually purchased in May of 2006! 12 years, and it still had not fell over. It did not pass the load test on the last service, so I replaced it just in case.
At the Odyssey battery dealer they had a memory saver that hooked up to the ODB port, I do not know if a OBD reader could do the same function. Might be worth looking up. Just a quick google search nets a bunch of alternatives.
firekat is offline   Reply With Quote
Old 05-29-2018, 11:32 AM   #3
sato
sato's Avatar
Drives: Dodge Patitas
I don't get how come you people had a battery for 6 or 12 years... hahaha. I've had to replace mine in 2 years time. Replaced with Optima RedTop, no issues.
PS I also replaced my older car with a RedTop, but had forgotten to turn in on while it was "resting" for 3 months due to suspension issues. It barely started up, but once I ran the car for a day, it is running and starting up just like new.
sato is offline   Reply With Quote
Old 05-29-2018, 01:18 PM   #4
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
extreme heat and cold can kill batteries.
why? is offline   Reply With Quote
Old 05-29-2018, 02:46 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
And lack of use... As I found out..
Old 05-29-2018, 03:55 PM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
I have my eyes on the Optima YellowTop for my style of usage (since I have a dash camera with parking mode functions). They're hella expensive haha but I'm sure they're worth it! I'll be doing this in the near future but just want to see how everyone's saving their memories while replacing their batteries.
2000 MR-S 5MT
2010-2012
Old 05-29-2018, 07:58 PM   #7
ze12o
Drives: BRZ 2015 DGM
did you perform the suggested normal maintenance of adding water to the battery?
ze12o is offline   Reply With Quote
Old 05-29-2018, 09:47 PM   #8
extrashaky
Drives: 2014 BRZ Limited
Seemed weak to me. That stock battery was a turd. It didn't take much to deplete it, and it was wimpy on starts. The car would actually stumble when I turned the lights on, which I didn't realize was a battery issue until I replaced it and the stumbling stopped. Once the guys at the dealership left the door open for a few minutes while they were changing the oil and had to jump it to get it started again. I started carrying a rescue jumper battery just in case.
I finally replaced mine with a Duracell AGM battery from Sam's Club, and the difference was immediate and noticeable. It starts right up the way it's supposed to, and it doesn't stumble around when I turn the lights on now.
Optima had a very good reputation while they were being made in the USA. Then right around the turn of the century they moved their manufacturing to Mexico and started having problems. Now they seem to be hit or miss. Either you get one that lasts seven or eight years, or you get a dud that lasts three months before stranding you somewhere. Some people have had to get their batteries replaced under warranty twice. Now that you can buy them in AutoZone, the AZ store managers dislike them because they have to deal with so many irritated customers bringing them back for replacement. Optima has a serious quality control issue but continues to ride on a reputation built up before the move to Mexico.
I'm not personally sure what to recommend instead. As I noted above, I put a Duracell AGM from Sam's in mine a few months back, but I haven't had it long enough to testify to its longevity. It's made by East Penn/Deka, which has a decent reputation. So far so good. It cranks better now than it ever did.
Lithium Ion Battery Replacement Benzin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 07:05 PM
Replacement Battery jasonojordan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 01-24-2017 07:15 PM
Wierd Electrical issue - no windows + no trunk after battery replacement Takumi788 Issues | Warranty | Recalls / TSB 7 11-11-2016 11:15 AM
Car Audio Battery Replacement brzstormtrooper Electronics | Audio | NAV | Infotainment 0 03-23-2016 08:38 AM
Replacement Battery slizoth Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-09-2014 03:04 PM
