#785 |
Drives: Audi A4 B7 2.0T Quattro
T04E 54 or 50 trim compressor seems like the way I would go combined with a motor thats able to reach 70k rpm, this should be able to feed the low end area 2000-3500rpm around 50-100% the lb/min flow I have today, starting at 8psi. Low end torque is the only priority here.
I dont know how much kw is need to do this, but there isnt much to pick from either with high rpm so will get something around 6kw and try to feed it with as much it can handle. Any tips would be usefull, this is the flow numbers from my current setup with the latest log (Maf g/s converted to lb/min) 2000 - 5 2500 - 8 3000 - 12 3500 - 19 4000 - 26 4500 - 28 5000 - 31 5500 - 34 6000 - 39 6500 - 40 6800 - 41 Did some calcs for a compact battery solution for a 44.4v system using two 22.2v packs ZIPPY Compact 4500mAh 6s 40c Lipo Pack w/XT90 6s 4.5Ah 40c = MAX discharge 180A 22.2V x 2 = 44.4v 180A x 44.4v = constant discharge 7.99kw, duration 1.5minutes (peak discharge 16kw) This should be plenty, not thinking about recharging while driving for the moment. Last edited by al3k; 05-27-2018 at 07:46 PM. |
#786 |
Drives: blue - Cosworth SC stage 3.0
the main trouble you have with applying an ESC on a powerful engine is you don't want any restriction at the top end
and with 41lbs / min thats 310 grams /sec thats a pretty big blower so if you have a TD04 with a 54mm wheel that's a good size to give the low end response at 75K rpm ( about 160grams/sec max airflow I think) but you'll then need a bypass valve to open up at high engine speed so it won't choke over 160 grams /sec all do-able of course |
#787 |
Drives: 2013 frs red
Sounds like more trouble than it's worth. Boost is supposed to build with rpm not decrease.
#788 | |
Edit: Sorry I think I misunderstood you, and forgot to mention the log values I posted was from 2nd gear WOT with the EFR6758 on my 2.0l so airflow would have been higher if started from 2000rpm in 4th and did the pull in the low end of the powerband. So i need to be able to pull around 10 - 25lb/min from 2k-3krpm instead of 5-12 which it currently is in 2nd. I will check the TD04 with 54mm wheel, Im trying to find a Compressor map. This is the T04 50trim: Last edited by al3k; 05-28-2018 at 01:16 PM. |
#789 |
Drives: 2014 GT86
Trying to ask from ESC too much, for it's boost to be on par with classic SC, imho will unreasonably rise kit complexity/weight/cost. More boost = bigger power from heavier battery dump pack consisting of double or quadruple batteries needed, that will cost more, will weight more, will be harder to find mounting space for, and probably more complicated controller for eg. charging & cooling will be needed, pack will charge longer to full charge. Imho Phantom ESC with mild boost was fine time proven compromise costs/implementation/gains wise.
| The Following User Says Thank You to churchx For This Useful Post: | DAEMANO (06-02-2018) |
#790 |
thanks for posting up the compressor map
it looks like if you run the compressor to 75K rpm ( about the limit of the electric motors it seems) then you'll get 25 lbs /min with a pressure ratio of 1.4 so thats not bad certainly good enough for a FA20, I'm considering making one for my RX8 and that drinks 25lbs / min at full chat |
#791 | |
#792 |
Looking at logs with my stock (k03) turbo, it looks like 15lb/min is plenty to match that small turbo spool up.
Making a system with less voltage and turbo rpm to reach this will also make it less complicated, but having a bigger motor could really help sorting out potensial bugging/coughing issues i guess. It probably doesnt sound exciting at all, I also realized there might be to small space for a proper bypass system afterall. But its doable with more customized piping. Also pressure ratio will need to be low as possible at 2000rpm or less you dont want to full boost a stock eninge with a 10:1 compression ratio, the stock turbo was showing 4psi @ 2100rppm and 10psi @ 2440rpm without knock retard, so somewhere between there should be good if intake temps dont increase |
#793 |
TD06-20G looks to have a very nice area which can be used with different motors 55000-75000rpm++
#794 |
Only trouble there is you will definitely need a bypass to avoid it being a restriction at high engine speeds
I'm assuming the x axis is in kg/sec? as even a stock FA20 is about 160g/sec flat out I prefer the look of the previous TD04 map as I need 220 g/sec or 29 lbs/min air flow at full revs and its looks like the OEM's have finally brought something to market too looks like the 1st one out of the gate is Audi as the latest TDi Q7 uses an electric charger to provide low end boost on top of the turbos https://jalopnik.com/this-is-how-audis- ... 1823681637 just need to find a crashed SQ7 and strip it mercilessly of the interesting stuff - hopefully the breakers won't cotton on too quick to this one |
| The Following User Says Thank You to Matt@Cosworth For This Useful Post: | Teseo (05-31-2018) |
#795 | |
Drives: frs
#796 |
Drives: toyota 86 2017
Maybe this is off topic, but wouldn't an electric motor directly driving the pulleys via a chain or belt be more efficient and also be smog legal, not require modification of fuel maps, intake, exhaust, etc.
#797 |
Drives: 2014 GT86
pcguru: how adding parts that will need extra maintenance and will introduce extra mechanical losses can enhance efficiency/change emission legality/not require ecu tune? :/
I can imagine only one scenario and only for efficiency bit, if one uses electric motor with different rpm range then is optimum for spinning turbine/compressor. But then egain choosing right electric motors seems wiser to me then using wrong one + adding mechanical parts to change gearing ratio. And how that can change something with emissions or tune? :/ |
#798 | |
this is not easy direct drive is right route |
| Tags |
| hairdyerperformance, only pulls hard one gear |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 07:42 PM |
| DUP THREAD MODZ PLZ DELETE KTHX | SloS14 | Forced Induction | 0 | 07-09-2013 06:41 PM |
| Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 03:47 PM |
| Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 03:16 PM |
| WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 10:20 PM |
