Old 05-27-2018, 10:40 AM   #1
stlgrym3
Switching from OFT to Ecutek
Has anyone done that? Is it really as simple as reload the factory ecu rom back to the car using OFT and then unmarried the device? Does this wipe all OpenFlash codes out of your ecu cleanly with no issue later on when install ecutek tune?
stlgrym3 is offline   Reply With Quote
Old 05-27-2018, 10:49 AM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes, I used the OFT in the past. I unmarried the device and flashed back the stock tune. Now I am using an Ecutek tune without any issues.
The Following User Says Thank You to nikitopo For This Useful Post:
stlgrym3 (05-27-2018)
Old 05-27-2018, 11:09 AM   #3
coxxoc
I did this last week. You need to flash your original rom onto your ecu using the oft. After that openflash manager will allow you to erase all data on the tablet. This “unmarries” the device from your car. Click the download button in openflash manager after erasing the device. It should say the tablet has never been used.
Do these steps before installing the ecutek license and flashing your ecu with pro ecu. Your oft will remain locked to your car otherwise.
coxxoc is offline   Reply With Quote
Old 05-27-2018, 05:16 PM   #4
stlgrym3
Do I have to connect the tablet to the car when unmarrying/erasing data from the tablet?
Old 05-27-2018, 05:24 PM   #5
Evangelion
Drives: 2017 GT86
Once the OFT is locked onto a vehicle, is there anyway to still unmarry it still? My tuner said it'd be no problem and ended up being wrong. Now I have an OFT collecting dust lol
Evangelion is offline   Reply With Quote
Old 05-27-2018, 06:11 PM   #6
steve99
Drives: FT86
Yes unfortunatly tuner is wrong. The oft need to write back the stock rom in its memory to your car. Unfortunately it cannot do this now as ecutek locks ecu to ecutek system.
If the tuner wrote back a stock tune to car with ecutek it would unlock ecu, but if you then used oft to write back the oft stock rom you will loose your ecutek licience.
If the tuner is prepared to renew your ecutek licience then you could unmarry oft that way.
Otherwise you wont be able to unmarry the oft easily.
I can do it but you would need to mail the oft unit and cables to me
chaoskaze (07-31-2018)
Old 05-27-2018, 09:20 PM   #7
coxxoc
You only need the tablet connected to the car to flash the original rom. Th erase data step is done when connected to a pc using openflash manager.
Old 05-27-2018, 09:33 PM   #8
steve99
Drives: FT86
yes hopefully he wrote back his stock rom with oft , before his tuner wrote ecutek. then he will be fine.
If not hes got a bit of drama
Old 06-16-2018, 03:06 PM   #9
stlgrym3
I’ll definitely write back the stock rom first using OFT before installing ecutek custom tune. Even though it means I may have to deal with couple days of CEL in between the tunes lol.
Old 07-31-2018, 09:41 PM   #10
stlgrym3
Sorry to bring this thread back, I’m ready to move on to ecutek next week. I will do the following with my OFT, please correct me if I’m wrong or missing steps.
1. Flash stock ROM back to the car
2. Connecticut OFT to my pc and delete all the tune files on it and unmarry it
Are these all?
Old 07-31-2018, 11:54 PM   #11
steve99
Drives: FT86
Are these all?
Yes
Write stock tune back from slot called original
Then on PC use erase function to completly erase and unmarty tablet, this is different to just erasing tunes. The full erase requires conmectoon to internet to talk to oft servers to confirm erase
stlgrym3 (07-31-2018)
Old 08-01-2018, 03:04 PM   #12
stlgrym3
Yes
After I install the stock rom back to the car, is there a way to verify the ecu indeed contains the stock rom?
Old 08-01-2018, 07:33 PM   #13
steve99
Drives: FT86
If the oft erases then rom was stock
I thnk thier is also an asterix next tovthe tune oft thinks is in ecu
Old 08-01-2018, 08:06 PM   #14
stlgrym3
I was referring to after I reload the stock ROM back into the car, can I use oft to check the current tune in the ecu is indeed stock rom?
Switching to 4x100 why? Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 11-23-2017 10:16 PM
Experience switching to a WRX/WRX STI orangespark Other Vehicles & General Automotive Discussions 36 11-27-2015 05:49 PM
EcuTeK RaceROM Map Switching - Restore Last Map on Startup Trick (VIDEO) DeliciousTuning Software Tuning 10 06-16-2014 07:23 AM
EcuTek map switching with OFT? andrew5826 Software Tuning 25 05-10-2014 04:23 PM
ecutek map switching defroster ft86me Software Tuning 8 08-04-2013 03:09 PM
