Old 05-25-2018, 03:04 PM   #15
RallySTI
Drives: 2013 Subaru BRZ
It's moot with Ventura's response. There's always some slop in the clutch mechanism which takes up pedal travel before the clutch begins to disengage. A mechanically stiff system will have a sharper engagement curve -- I'm making up that term -- than a sloppier one with the same holding force.
I suspected that there might be something special about the pressure plate making the movement more precise. I'm over it.
There is some defection in the diaphragm spring and also the steel stamping/clutch cover during the diaphragm spring movement. This deflection does delay the point where the pressure plate starts to lift during the spring travel.
RallySTI is offline   Reply With Quote
DIY Clutch Replacement Supermassive DIY (Do-It-Yourself) Guides 217 08-27-2023 12:35 PM
Clutch replacement pinetree Engine, Exhaust, Transmission 21 05-03-2017 08:48 AM
Clutch pedal feels super light Euphues Issues | Warranty | Recalls / TSB 33 09-17-2015 02:43 PM
Clutch replacement Thatguyjeremy Engine, Exhaust, Transmission 0 02-28-2015 04:22 AM
Clutch/flywheel replacement? bucket BRZ First-Gen (2012+) — General Topics 1 11-19-2012 12:25 PM
