Old 05-25-2018, 11:53 AM   #309
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by jbailey8748 View Post
That oil pressure seems excessively high. Is the guage reading correctly
Sent from my Pixel using Tapatalk
Yes it is correct.
Old 05-25-2018, 02:24 PM   #310
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Yes it is correct.
Check this guy's video out. May answer a question or two for you.
jbailey8748 is offline   Reply With Quote
The Following User Says Thank You to jbailey8748 For This Useful Post:
AllThePeat (09-13-2019)
Old 05-25-2018, 09:53 PM   #311
Irace86.2.0
Thanks. I’ve seen it before.
The video demonstrates and discusses exactly what I was saying and asking without really addressing this product. Like he mentions, many oil coolers have thermometers that open the flow to the oil cooler, but there is always flow, so in cool weather after cold starts the oil will be getting cooled which will extend getting the oil up to good operating temperatures. It seems like this product could do the same, especially since there is no built in thermometer to limit oil flow to the cooler. But, it does circulate oil next to the coolant which should heat the oil on cooler days, so this product would be better than other oil coolers, potentially.
Old 05-25-2018, 11:49 PM   #312
churchx
churchx's Avatar
Drives: 2014 GT86
Irace86.2.0: thermostat (to switch flow path depending on temps to keep temps steady), not thermometer (to measure temps)
Old 05-26-2018, 12:48 AM   #313
CSG Mike
CSG Mike's Avatar
Overcooling your oil, is about the same as overcooling your coolant.
Just how the thermostat keeps your engine from being overcooled, the thermostatic plate prevents your oil from being overcooled.
Tristor (05-28-2018)
Old 05-28-2018, 06:43 PM   #314
Nightflo
Nightflo's Avatar
Turbos don't get red hot unless you're driving them hard.
For that matter, a *STOCK* WRX overheats coolant in 3 back to back pulls on the dyno. MGT2259S. You're welcome to look up specs yourself; it is a *water cooled* turbo.
I think you confuse the conducted heat of the oil in the turbocharger, versus the frictional heat generated in the oil by RPMs.
It's a very simple test you can do yourself. Go on the highway, and watch your oil temps by cruising in 3rd gear. You may be shocked at how quickly they climb.
I have oil temperature and pressure gauge. Can I use an sandwich plate (Perrin or TRD) with temp and pressure ports below the jacksonracing sandwich plate? Need it to clear JDL intake? I have the older version of the JR dual radiator. I was thinking just buying the JR new sandwich plate but I’m not sure if oil lines to AN fitting on JR sandwich clear.
Nightflo
Fresno, CA
BOOSTED ‘15 BRZ
Since ‘14
Nightflo is offline   Reply With Quote
Old 05-28-2018, 09:37 PM   #315
CSG Mike
CSG Mike's Avatar
You can use any sandwich plate that has compatible threading and ports!
Old 05-28-2018, 10:17 PM   #316
Nightflo
Nightflo's Avatar
So is it okay to put the trd sandwich first and stack the JR sandwich on top of the TRD as well? Similar to this except it’ll have the spacer and Jacksonracing sandwich plate on top of the TRD sandwich. (I have he older version of Jackson racing dual radiator sandwich) -I need to clear the turbo intake.
Nightflo
Fresno, CA
BOOSTED ‘15 BRZ
Since ‘14
Old 06-18-2018, 07:37 AM   #317
falcon_wizard
Drives: BRZ 2013
Good day,
Is there any feeback on the long term reliability of this cooling solution, particularly regarding a suitable a stainless braided hose option to avoid risk of hose failure due to chafing or kinking ?
I am looking for a cooling solution for my intercooled Turbo setup, and this cooler option seems very attrative, however since my vehicule is also my year round daily driver including cold, icy and snowy winters, I am looking for a solution with highest reliability potential and would appreciate any feedback. I experienced consistently up to 212f water temp and 280F oil temp with 5w40 oil during multiple sessions at an HPDE event, which seems to indicate a strong need for an oil cooler if I am interested in attending other HPDEs in the future. Normal driving temps would not usually exceed 240F.
Thank you
falcon_wizard is offline   Reply With Quote
Old 06-18-2018, 10:56 AM   #318
djezlee
Drives: 2017 BRZ Limited
Wow... That's hot! I was reaching 270F oil temp on the Autobahn here in Germany with extended rides at around 115mph. I changed my radiator out for the beloved JR combo radiator/oil cooler about 2 months ago so I cant speak for long term, but I am pretty happy so far with the cooling ability on my NA BRZ. I am averaging around 210-215f oil temps at high speeds (190ish at normal highway speeds). I don't believe the braided hoses are necessary at all if you install it right. There's no chaffing from what I can see and I have been a little paranoid, checking every time I get gas.
djezlee is offline   Reply With Quote
The Following User Says Thank You to djezlee For This Useful Post:
CSG Mike (08-14-2018)
Old 06-22-2018, 12:37 PM   #319
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
Installed my radiator/oil cooler a couple weeks ago. First track day with it was mid 90s ambient temp. Oil maxed at 233F once, and maintained right around 230 through four 20 minute sessions. Whereas previously I could only go about 10 minutes and temps would get above 260. Gotta say thanks to JR for a great product! The instructions were well written out, but I really could've used some pictures with them. But hey, that's what the internet's for, right?
Now I'm just hoping it will still fit and perform as well in a couple years after the addition of a turbo. Fingers crossed!
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
The Following 4 Users Say Thank You to coryandy For This Useful Post:
bhmax (11-17-2019), dowroa (06-24-2018), JeremyR (06-22-2018), weederr33 (06-23-2018)
Old 06-22-2018, 01:11 PM   #320
djezlee
I am hoping mine performs well after my turbo install this winter also. and I agree about the lack of pics!
Old 06-22-2018, 02:50 PM   #321
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Originally Posted by falcon_wizard View Post
Good day,
Thank you
You can cut your own hoses and attach them to -10 an fittings with the appropriate bend. I've got my ss lines mocked up and ready, but haven't had the time yet to install.
tyler_win_photo is offline   Reply With Quote
Old 06-22-2018, 09:37 PM   #322
falcon_wizard
Drives: BRZ 2013
Thanks for the feedback, I've just ordered the JR dual cooler and will be able give feedback on how it performs after its installed, but based of the feedback here, I suspect it will be exactly what I need. My Turbo setup puts up to 340hp, if it can bring oil down from 280F down to 240F or less, It'll be just fine for my 5W40 oil.
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
