#15 | |
How much of a drop? Arguably you need quality dampers on the street just as much as on a track, most streets are in significantly worse shape than a track and with crap dampers (and overly stiff springs) you'll be bouncing and skipping around.
| The Following 4 Users Say Thank You to wparsons For This Useful Post: |
#16 |
Country Boy 4 Life
I always read these threads...
I have springs because of them.... http://www.ft86club.com/forums/showthread.php?t=80158 http://www.ft86club.com/forums/showthread.php?t=79526 http://www.ft86club.com/forums/showthread.php?t=124794 http://www.ft86club.com/forums/showthread.php?t=66725 http://www.ft86club.com/forums/showthread.php?t=51505
I LIKE TIRES! |
| The Following 3 Users Say Thank You to Leonardo For This Useful Post: |
#17 |
Drives: 2019 BMW ///M4
I have the Tein Flex A installed on my FRS on stock wheels with Michelin Pilot Sport AS3+. My number one reason why I got the Flex A is because I wanted a softer ride. I have a 2013 FRS so the suspension is stiffer than 2015+. I have the ride height set to what Tein Recommended. The Flex A has Hydraulic Bump stops vs rubber ones on the Flex Z.
I have tried running the car on max stiffness and it feels like a boat rocking back and forth on normal streets. I have tried the recommended 8 clicks from stiff and it feels like stock which I find is a little too stiff for the roads I have in LA. I have tried setting it to 16 clicks which is Max Dampening, but it feels too floaty for the car but you can still feel really harsh bumps in the road. I have it set to 10 clicks and it's perfect. Softer than stock but still handles well. I don't plan to track my car so daily drivability is my #1 concern. If I had to do it again, I would get the Normal Flex Z instead of the A. I don't think I notice much of the HBS but the Flex A is rebuildable where the Z is not. When the time comes to replace the coils again, I would rather rip and replace everything than just the damper. Tein is also a good brand, the Flex Z is around 850 dollars where the Flex A is around 1100.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#18 |
Drives: C5, GT-86, '24 Colorado TrailBoss
love my Meister R coilovers check them out
| The Following User Says Thank You to SuperTom For This Useful Post: | GoZ21 (05-20-2018) |
#19 |
Drives: FR-S Whiteout
With $1000 budget... Flex-Z can be had for less than $800 and you'll still have money left over to get camber kit, which you may or may not even need. Surprisingly good for dampers at this price point.
Intent > Content
cowardice is the mother of cruelty. |
#20 |
Drives: 2014 GT86
Camber kit? o_O
Flex Z & Flex A sets include own camber plates. |
#21 |
Drives: 2017 BRZ
I'd venture to guess the thought was to add rear LCA. Getting all that stuff aligned will take some funds too.
| The Following 3 Users Say Thank You to cjd For This Useful Post: |
#22 |
Drives: 2013 Asphalt Frs
#23 | |
For everyone saying that 1k coils are not worth the buy, this car will only ever see public roads and for all I care the coils could have the performance characteristics of stock suspension, if it was height adjustable id use that. |
#24 |
Drives: Crapcan
On bumps or hard cornering you will rub the inner fender liner in the front with that much drop. Just fyi.
#25 |
Drives: 2014 GT86
Planned drop of >2"? That is almost halving stock ground clearance of 4.9" and if it had been stock shocks, it would leave 0.5" bump travel & ride on bumpstops (from ~2.5" bump travel including bumpstops & ~ 3.5" droop travel). Coilovers can do better for this case, but ..
I guess it's not worth to give any advises based on performance/handling/comfort & compliancy at this point. Extreme lowering car for very slammed looks is obvious priority to everything no matter illeffects. I predict though that it won't be as simple keeping budget low though, as at higher drop levels much more parts need to be changed then just coilovers. |
#26 |
Drives: 2013 Raven FR-S
Yeah a 2” drop on this car is a lot. Ideally you’d want to install taller ball joints and differential risers to compensate. I’d say 99% of people who slam these cars don’t do that. It does lead to geometry issues and broken CV joints though.
#27 | |
2" drop will require really stiff springs and in the $1000 price range will ride way worse than stock, regardless of how you adjust them. Plus, with a 2" drop you'll be compromising the suspension geometry and it'll handle worse than stock.
#28 |
Drives: Crapcan
I'm on 2" of drop and it isn't too bad. There is a bit of rub but that is about it. I even had an instructor take my car out for a couple laps and he thought it rode pretty well on a rough track with lots of curbing.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | GoZ21 (05-20-2018) |
| Tags |
| coilovers |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 01:09 PM |
| FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns | b2autodesigns | Brakes, Suspension, Chassis | 177 | 02-09-2015 12:34 PM |
| WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers | ProjectBrz | Brakes, Suspension, Chassis | 1 | 04-15-2014 01:21 AM |
| * BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * | Speed Element | Brakes, Suspension, Chassis | 21 | 03-03-2014 09:56 PM |
| FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers | ill roller | Brakes, Suspension, Chassis | 5 | 12-14-2013 04:02 PM |
