Old 05-07-2018, 06:02 PM   #379
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Originally Posted by FT86Z View Post
The cold start is much louder now thank you guys for the guidance. Only thing is the brief dip to 500 rpm before it shoots back up to 1400. Can't figure it out for the life of me
Why did you want the loud cold start back? All it does is heat up the catalytic converter faster for emissions purposes. I'm pretty sure my neighbors were glad to see it disappear on my car. lol
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
SuperTom (05-07-2018)
Old 05-07-2018, 06:51 PM   #380
tomm.brz
Drives: brz 2017 hksv2
loud cold start bark is cool
FT86Z (05-08-2018)
Old 05-10-2018, 10:51 AM   #381
Timmy_Jones
Spun
Drives: 23' Supra
You must not have any neighbors or family...or you have a stock exhaust.
Timmy_Jones is offline   Reply With Quote
Old 05-10-2018, 10:54 AM   #382
tomm.brz
i dont have a loud cold start, i m catless
but it still is cool
Old 05-11-2018, 02:37 PM   #383
chromes
Drives: BRZ Ts
OTS Maps for ZA1JN10C (MY2018 US 6MT); v4.03
Created by: Anthony Cardinale for Shiv Pathak
Modified on: Sat, 5 May, 2018 at 8:13 PM
New v4.03 beta tunes now available for all USDM GT86s (including 2017+). They now have Launch Control and Flat-Foot-Shift (these features will need to be setup/adjusted at home)!
*** NOOB ALERT ***
Hi there,
i'm also a Ts 2018 owner, and was able to sucessfully push in stage 1 map.
Only thing i dont get right is where i can adjust or activate launch control and flat foot shift. Does it have to be ''activated'' trough romraider or it's possible via the OFT itselft?
Sorry if it's been asked millions of times, but i wasn't able to get a clear answer going trough the ''search'' option on the site...
chromes is offline   Reply With Quote
The Following User Says Thank You to chromes For This Useful Post:
SkyeHack (05-11-2018)
Old 05-11-2018, 06:38 PM   #384
Jasonb
Drives: 17 Series Yellow BRZ
*** NOOB ALERT ***
Hi there,
launch control will work by default, it'll just be set way higher than it should be.
Jasonb is offline   Reply With Quote
Old 05-11-2018, 08:03 PM   #385
smg1138
smg1138's Avatar
While we're on the topic, how do you lower the RPM's on the launch control? It's pretty much useless being set at 5,500.
Old 05-11-2018, 09:29 PM   #386
freerunner
freerunner's Avatar
Drives: GT86
It's a negative offset to the rpm fuel cut limit. OTS default is 7500 or 7600. So if you want your launch control to limit at about 2500 rpm just insert 5000 into the launch control table.
freerunner is offline   Reply With Quote
Old 05-17-2018, 07:19 AM   #387
redhalo
Drives: MY20 Hakone Toyota 86
MY17 AT K00D E85 tune here. I've noticed that my rpms spike for a sec on a cold start when putting the car in gear. This causes an ever so slight jerk despite my foot on the brake. I suspect it's the multitude of "idle speed target" maps not matching and picking a different rpm once in gear.
Which of the 9 "idle speed target" maps are for what conditions and are they safe to modify? With cold start removed do they even need to be anything other than 700 across the board or is the higher rpms just for getting the engine up to temp? My intent is to make the maps for base start and in gear match so that there isn't a spike at cold start.
redhalo is offline   Reply With Quote
Old 05-17-2018, 07:58 AM   #388
tomm.brz
i dont think anyone knows which idle maps works at a spec time..usually you could put them all the same to have a standard controlled behaviour
Old 05-17-2018, 07:59 AM   #389
steve99
Drives: FT86
Check the MAF OFFSET AFTER START tables are same ie the in gear and in neutral tables are same
redhalo (05-17-2018)
Old 05-17-2018, 11:18 AM   #390
Baron_T
Drives: 2014 BRZ
I put those all back to stock
After a bunch of low end tuning and dialing in my MAF and Engine Load Compensation fairly well, and raising my fueling to around 13 below 2200 to avoid bogging down, I couldn't find any advantage to the OFT raising those idle settings up. So I set mine all back to stock B01C (i.e. 650 RPM when fully warm).
Baron_T is offline   Reply With Quote
Old 05-17-2018, 06:10 PM   #391
redhalo
I do believe you are on to something here. I checked this morning and with a cold start my rpm's jump to 2000 and back down when I put it in gear. None of my idle maps go any higher than 1200 and my MAF correction maps do not match. I'm assuming copying IN GEAR over NEUTRAL would be fine.
Old 05-18-2018, 03:23 AM   #392
steve99
Drives: FT86
yes
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
