Old 05-08-2018, 11:33 AM   #15
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
The seal won't keep all the water out. No car windows do. It is impossible to make a 100% water tight seal on a window. You see streaks on frameless since there are guides in the center that most framed windows don't have. There is nothing they can do to fix it since it ain't broke.
Sure. I mean, if I take a power washer and shove it in the gap, water will get in there. I've just never seen moisture get past the seal like this in any other car. And it's only on the driver's side. In the same conditions, the passenger side window doesn't have the same streaks.
bkharmony is offline   Reply With Quote
Old 05-08-2018, 12:01 PM   #16
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Originally Posted by bkharmony View Post
2017 86 here and I'm getting moisture past the driver's side door seal. When I drive in heavy rain, the next day or later that night, when I roll the window down/up, there will be streaks of moisture on the window.
I'm due for a service, and I think I need to make a warranty claim. This seems like something that could get a lot worse.
naw, it shouldn't..my 2013 had nearly the exact same wet spots as the OP whenever my car was in heavy rain or had gone through a car wash and over 60,000 miles it didn't get any worse..in fact I fixed it by keeping the seal clean & lightly lubricated. Perhaps it is dry out there in TX like in AZ. So far my 2016 hasn't had the same issue..
HKz is offline   Reply With Quote
Old 05-08-2018, 12:10 PM   #17
Maybe all just in what you are used to. We get so much torrential rain here that all my cars have done it. Both my windows streak the same but it is just another rainy day in Ontario thing. At least you don't get rain in the day that freezes solid at night. That really messes with things.
Old 05-08-2018, 01:48 PM   #18
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
I should mention it intermittently squeaks when rolling up/down, as well, both in rain and dry conditions.
Old 05-08-2018, 01:49 PM   #19
That is the wet guides. You can talk to them but I doubt there is anything they can do.
HKz (05-08-2018)
Window seals nanofamous Issues | Warranty | Recalls / TSB 21 05-29-2016 08:59 PM
Injector Seals went Bad while tuning my car whitefrs Forced Induction 128 08-20-2013 01:19 PM
Left gas cap off and door open all night in heavy rain Deepmist Issues | Warranty | Recalls / TSB 27 05-07-2013 04:58 PM
Any water drips from above door in rain? josby BRZ First-Gen (2012+) — General Topics 9 01-17-2013 07:22 PM
Bad window seals? Dzeremijs Issues | Warranty | Recalls / TSB 18 10-26-2012 04:24 PM
