Old 05-01-2018, 08:00 PM   #1
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
what are these 2 bolts I got in my ace header box?
I found these in the box, what are they for? Did I get bonus bolts? Also what are the torque specs on everythig? I cant find any instructions
https://imgur.com/a/o0A1xnz
Old 05-01-2018, 09:47 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
That's how you attach the front-pipe to the header - the flange is threaded.
The Following User Says Thank You to cjd For This Useful Post:
whataboutbob (05-01-2018)
Old 05-01-2018, 09:56 PM   #3
Breadman
Breadman's Avatar
turns out the fit on the over pipe. so i guess they are for the overpipe to mid pipe. weird how they were just floating in a box
Old 05-04-2018, 12:00 AM   #4
websunil77
Drives: My car is Honda civic
It's the right one.
websunil77 is offline   Reply With Quote
Old 05-18-2018, 06:09 PM   #5
brybot
Drives: 13 DGM BRZ 6MT
So what size are those? Purchased a used ACE header and it appears the seller didn't include any. Trying to remove the studs from the stock overpipe... not sure if that's the way to go.
brybot is offline   Reply With Quote
Old 05-18-2018, 11:40 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Not sure the studs will work, but you should be able to find bolts that work at an auto parts store. Bring the op portion of the header in, find bolts that fit.
Honestly no idea what grade is recommended for the exhaust.
Old 05-21-2018, 12:23 PM   #7
brybot
Thanks. And you were right - those studs wouldn't work. Threads in the ACE OP are M10x1.25 so were easy to find at the hardware store. If anyone reads this down the road, I went with 30mm length, which proved to be about perfect.
The Following User Says Thank You to brybot For This Useful Post:
Plumbus (12-07-2020)
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 10:06 PM
Overpipe to Header Bolts/Nuts 808BRZ Engine, Exhaust, Transmission 2 07-25-2016 09:41 AM
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 03:26 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
