Northwest AK, ID, OR, WA
Old 09-01-2013, 04:20 AM   #1
stockysnail
Just the tip
stockysnail's Avatar
Lightweight aluminum drive shaft installed.
I installed my new Axle-Exchange aluminum drive shaft that weighs only 12lbs yesterday. I also took a video of how cool my car sounds with it in. My car sounds like it has a supercharger now as the faster the drive shaft spins the more it sounds like a supercharger whine. See my review and video on my build thread.
http://www.ft86club.com/forums/showthread.php?t=24596
Old 09-11-2013, 02:33 PM   #2
Ooops
Wannabe Enthusiast
Drives: 2013 BRZ Limited White Pearl
Where might one acquire an aluminum drive shaft? Direct from Axel-Exchange, or someplace local, performance shop? Any Pictures?
TKS
Ooops is offline   Reply With Quote
Old 09-11-2013, 06:52 PM   #3
stockysnail
Just the tip
TKS
I got mine direct from axle exchange at axle-exchange.com
Old 05-03-2018, 12:40 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Super epic thread revival: since I see you're still active, how is the driveshaft homing up? How was the comparison from stock? Doing this mod soon, not a lot of information on the forum about it.
Old 05-03-2018, 02:30 AM   #5
stockysnail
Just the tip
I no longer have it as I thought the TRD short shifter mixed with it was the issue for why the short shifter wasn't working properly. I took it off and sold it. The issue ended up being the trans bushings. Ended up selling the TRD short shifter too. Definitely don't recommend the short shifter. I haven't gotten around to buying another drive shaft. It's a cool mod. Makes the revs slightly free-er. Makes a cool noise like a supercharger almost since the aluminum is hollow and picks up some vibration. Is it worth the $, I'm not sure, but I enjoyed it and would buy it again, especially if I can find a used one or there's a sale. It's fairly simple to install.
The Following User Says Thank You to stockysnail For This Useful Post:
DarkPira7e (05-03-2018)
Old 05-03-2018, 10:57 AM   #6
DarkPira7e
DarkPira7e's Avatar
Thank you for the input! I was expecting it'd make a difference with on/off throttle delay and harshness, did you notice any difference there? Like when you hit the gas, I was thinking it'd smooth out the transition since you're removing the carrier bearing
Old 05-03-2018, 01:34 PM   #7
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
How is it for vibration? I tried the Driveshaft Shop aluminum drive shaft and it vibrated so bad I sent it back.
Lunatic is offline   Reply With Quote
Old 05-03-2018, 02:11 PM   #8
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
I can speak for the carbon DSS auto driveshaft and it is amazing. I managed to buy it used for a steal too.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 05-03-2018, 06:40 PM   #9
new2subaru
Weight Weenie
Drives: 15 FR-S
Carbon fiber has the advantage of being able to absorb vibrations.
Old 05-03-2018, 08:27 PM   #10
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Motor mounts fix that way more than driveshaft
Decay107 is offline   Reply With Quote
Old 05-03-2018, 09:38 PM   #11
DarkPira7e
DarkPira7e's Avatar
If my mounts were bad, I'd agree. These motors really don't weight enough to merit solid mounts unless you're running FI. My old 3000gt vr4's engine on the other hand..
Old 05-03-2018, 09:40 PM   #12
Decay107
Decay107's Avatar
You're wrong. The stock mounts are too soft and the primary contributor to the rubber bandy feeling drivetrain. Many of us have swapped out to the STi mounts (NOT solid) and seen a huge improvement.
The Following User Says Thank You to Decay107 For This Useful Post:
Old 05-03-2018, 09:42 PM   #13
DarkPira7e
DarkPira7e's Avatar
I'll give it a shot and see! Being wrong in this case would really make me happy, thank you
Old 05-04-2018, 02:59 AM   #14
stockysnail
Just the tip
I have the Perrin engine mounts and agree that they make everything crisper and more direct with very minimal vibration and noise. When I had the aluminum drive shaft I didn't notice any more vibration, just a slight increase in noise.
slizoth (02-26-2019)
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 08:53 PM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 02:48 PM
GFB 3-Piece lightweight aluminum pulley kit Touge Factory Engine, Exhaust, Transmission 60 06-03-2013 02:52 PM
KARTBOY Lightweight Aluminum Crankshaft Pulley! RallySport Direct Engine, Exhaust, Bolt-Ons 0 10-29-2012 03:55 PM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 02:40 PM
