| Northwest AK, ID, OR, WA |
Just the tip
Lightweight aluminum drive shaft installed.
I installed my new Axle-Exchange aluminum drive shaft that weighs only 12lbs yesterday. I also took a video of how cool my car sounds with it in. My car sounds like it has a supercharger now as the faster the drive shaft spins the more it sounds like a supercharger whine.
See my review and video on my build thread.http://www.ft86club.com/forums/showthread.php?t=24596
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#2 | |
Wannabe Enthusiast
Drives: 2013 BRZ Limited White Pearl
TKS |
#3 |
Just the tip
I got mine direct from axle exchange at axle-exchange.com
#4 |
Rust bucket enthusiast
Super epic thread revival: since I see you're still active, how is the driveshaft homing up? How was the comparison from stock? Doing this mod soon, not a lot of information on the forum about it.
#5 |
Just the tip
I no longer have it as I thought the TRD short shifter mixed with it was the issue for why the short shifter wasn't working properly. I took it off and sold it. The issue ended up being the trans bushings. Ended up selling the TRD short shifter too. Definitely don't recommend the short shifter. I haven't gotten around to buying another drive shaft. It's a cool mod. Makes the revs slightly free-er. Makes a cool noise like a supercharger almost since the aluminum is hollow and picks up some vibration. Is it worth the $, I'm not sure, but I enjoyed it and would buy it again, especially if I can find a used one or there's a sale. It's fairly simple to install.
| The Following User Says Thank You to stockysnail For This Useful Post: | DarkPira7e (05-03-2018) |
#6 |
Thank you for the input! I was expecting it'd make a difference with on/off throttle delay and harshness, did you notice any difference there? Like when you hit the gas, I was thinking it'd smooth out the transition since you're removing the carrier bearing
#7 |
Drives: 2015 Raven FRS
How is it for vibration? I tried the Driveshaft Shop aluminum drive shaft and it vibrated so bad I sent it back.
#8 | |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
I can speak for the carbon DSS auto driveshaft and it is amazing. I managed to buy it used for a steal too.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
#9 |
Weight Weenie
Drives: 15 FR-S
#10 |
Turning is for Nerds
Drives: 35 characters is not enough
Motor mounts fix that way more than driveshaft
#11 |
#12 |
You're wrong. The stock mounts are too soft and the primary contributor to the rubber bandy feeling drivetrain. Many of us have swapped out to the STi mounts (NOT solid) and seen a huge improvement.
| The Following User Says Thank You to Decay107 For This Useful Post: | DarkPira7e (05-03-2018) |
#13 | |
#14 |
Just the tip
I have the Perrin engine mounts and agree that they make everything crisper and more direct with very minimal vibration and noise. When I had the aluminum drive shaft I didn't notice any more vibration, just a slight increase in noise.
| The Following User Says Thank You to stockysnail For This Useful Post: | slizoth (02-26-2019) |
| PST Carbon Fiber Drive Shaft Installed | msile | Engine, Exhaust, Transmission | 155 | 08-28-2018 08:53 PM |
| Raceseng | Lightweight Billet Aluminum Tow Hook | Raceseng | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 08-27-2013 02:48 PM |
| GFB 3-Piece lightweight aluminum pulley kit | Touge Factory | Engine, Exhaust, Transmission | 60 | 06-03-2013 02:52 PM |
| KARTBOY Lightweight Aluminum Crankshaft Pulley! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 0 | 10-29-2012 03:55 PM |
| Does FRS come with Carbon drive shaft? | STi88 | Engine, Exhaust, Transmission | 30 | 07-30-2012 02:40 PM |
