Old 01-30-2018, 05:14 PM   #253
Tor
Tor's Avatar
Drives: Toyota GT86
Everyone seems very hung up on heating up the oil. But remember this, we are not living in the 1960ies anymore. Modern multigrade oil is going to lubricate fine at low temps.
What you really want to be sure is that the engine internals are up to temp so metal parts like pistons have expanded to their correct tollerances. The oil temp is probably not a very good indication of the temperature of the internal engine components if you heat it up artificially.
Tor is offline   Reply With Quote
Old 03-05-2018, 08:40 PM   #254
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
2017+ Compatibility
We have updated the Dual Radiator/Oil Cooler for the 2017+ 86/BRZ. Now includes a new oil cooler adapter with added features.
Press Release:
https://jacksonracing.com/jackson-ra...8-fr-s-86-brz/
Video:
[ame="https://www.youtube.com/watch?v=SlLWoF5UthA"]Jackson Racing 86/BRZ Dual Radiator Oil Cooler - YouTube[/ame]
Jackson Racing is offline   Reply With Quote
The Following 10 Users Say Thank You to Jackson Racing For This Useful Post:
Bonburner (04-26-2018), chaoskaze (03-09-2018), churchx (03-06-2018), CSG Mike (03-05-2018), Hades (03-09-2018), Harvie1031 (03-06-2018), killboy (03-06-2018), Tristor (03-27-2018), weederr33 (03-06-2018), Williampreza (03-06-2018)
Old 03-06-2018, 11:32 AM   #255
Grady
Grady's Avatar
Press Release:
Video:
Dam you!!!!! Well there goes more of my Sailing budget!
The Following User Says Thank You to Grady For This Useful Post:
Jackson Racing (03-22-2018)
Old 03-06-2018, 11:51 AM   #256
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
The issue of getting oil up to operating temps quickly isn't much due to lubricity - it's so condensation will evaporate quickly and keep the oil in serviceable condition for longer time/distance.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 03-06-2018, 12:49 PM   #257
Icecreamtruk
Drives: Track preped NA FRS
How is evaporating condensation quicker going to keep the oil in serviceable condition for longer? I see about 0 relation between those 2 things?
Icecreamtruk is offline   Reply With Quote
Old 03-06-2018, 01:08 PM   #258
venturaII
venturaII's Avatar
You don't see a correlation between removing water from oil and oil service life..? I think there's an overused meme for this somewhere...
Old 03-06-2018, 01:47 PM   #259
Icecreamtruk
I dont see why evaporating the water 2 minutes earlier has anything to do with it. You will evaporate it anyways after the oil is up to operating temps. How is heating the oil faster changing anything in this?
Edit: Before I get quoted on this with another incomplete answer. Picture this, you have 2 bowls with salted water in them. You want to get rid of the water and just keep the salt in. You put them both to heat up but at different heating speeds. They both get up to temperature and both end up evaporating all of the water. How is evaporating the water faster helpfull in any way (unless you tell me you turn on the car and turn it off after a minute or so of driving, if so you are your own undoing).
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Tor (04-26-2018)
Old 03-06-2018, 06:01 PM   #260
venturaII
venturaII's Avatar
You answered your own question. If the oil gets up to operating temp faster, then it has more time to remove moisture. If you're on a 500 mile trip, then it isn't an issue. But if you're driving 10 minute errands here and there, like how 90% of daily driving is done, then it's a much bigger issue.
The Following User Says Thank You to venturaII For This Useful Post:
CxG (03-09-2018)
Old 03-06-2018, 11:56 PM   #261
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
One of the things to remember with this type of unit is it will not begin to warm the oil until the thermostat opens and the water in the radiator begins to warm up. Depending on the ambient temp that could take a while.
As a non-track oil temp regulator the oem subie hardware would probably work better.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
JDM4E (03-08-2018), venturaII (03-07-2018)
Old 04-24-2018, 01:16 PM   #262
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
I just installed the new DROC on my 2017 BRZ with a friend yesterday. Everything fit perfect, super easy. The instructions had me worried saying it was difficult to get the radiator out and in but it was a breeze following the instructions. No issues at all with kinking lines, fits perfectly around the stock airbox. Awesome product as far as fitment and installation and the engine didn't explode when I fired her up so that's good. Still need to get the bumper back on as we were running pretty late last night, but I'll be driving her today.
Horrid_Funk is offline   Reply With Quote
The Following User Says Thank You to Horrid_Funk For This Useful Post:
CSG Mike (04-24-2018)
Old 04-24-2018, 03:39 PM   #263
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I have the Forester XT regulator. Would this be able to be used with that or would there by clearance issues?
Old 04-26-2018, 01:34 AM   #264
Hawk77FT
Drives: GTS 86
I am actually wondering the same thing. With that said however, looks like there might not be much of a benefit in running both. The JR one has a massive cooling capacity compared to the small core the Forester one has. Plus, it looks a bit cleaner. Once i change my intake I will hook this up and let you know.
Hawk77FT is offline   Reply With Quote
The Following User Says Thank You to Hawk77FT For This Useful Post:
Irace86.2.0 (04-26-2018)
Old 04-26-2018, 01:45 AM   #265
stlgrym3
are aftermarket oil coolers only for FI cars? what benefits they have for cars with just bolt-ons and tuned?
stlgrym3 is offline   Reply With Quote
Old 04-26-2018, 02:03 AM   #266
CSG Mike
CSG Mike's Avatar
They keep your oil temps from getting too high, which can result in potentially insufficient lubrication and subsequent engine failure.
Oil coolers are recommended for any car that sustains elevated RPM, even if it's just a canyon drive.
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
