Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Belt Tensioner Pulley Wobble
Is this normal for the tensioner pulley to wobble between the power steering pulley and crank pulley? Could it be misfiring despite no code showing up? I'm concerned that it could be DI seals or the camshaft position sensor out of whack.
[ame="https://www.youtube.com/watch?v=uudLANdap_U"]https://www.youtube.com/watch?v=uudLANdap_U[/ame] Some background - the car was warmed up at idle. I'm concerned since I had a p401 code pop up - misfire cyl 1. Since then I've swapped cyl 1 and 3 coils to see if that was the culprit and been driving on it for 2-3 weeks, no more CEL since then. I did have p351 code about a year ago - ignition coil malfunction, and replaced cyl 1 coil as a result of it. So swapping the newer cyl 1 coil to cyl 3 seems strange that it fixed the issue (so far). Thoughts?
| The Following User Says Thank You to hyper4mance For This Useful Post: | kowalski (02-11-2019) |
#2 |
Well, first off, I don't believe the pulley movement has anything to do with your past/present electrical problems.
I wouldn't worry about that much pulley movement ...... I'd just keep an eye on it. Of course, @Ultramaroon would recommend replacing the idler pulley ...... ![]() Bubba would just give it shot of oil ...... ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | hyper4mance (04-26-2018), mswbrz (03-08-2021) |
#3 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If it was deviating out out of plane I'd worry a lot more.
Each cylinder does not provide exactly the same impulse in their cycle. At an idle, the difference is exacerbated even more than at higher output. The idler was put in there to smooth out exactly those impulse differences. If you're tuning it, find out which system is under performing and boost it a little. edit: It's not going to break anything.
"I gotta rock." -- Charley Brown |
| The Following 2 Users Say Thank You to bcj For This Useful Post: | hyper4mance (04-26-2018), Tcoat (04-25-2018) |
#4 |
It is doing exactly what it was designed to do. Zero issues there.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#5 |
[insert cool phrase here]
Drives: BRZ Premium
looks normal to me. Misfires on the other hand is not related to a pully.
If your still worried about replace it. It's cheap and a quick 10 minutes of your life. Unless it goes sideaways. Which it might. But that's just me.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#6 |
The Dictater
Drives: '13 Red Scion FRS
Your cheap and a quick 10 minutes of my life?
#7 | |
Absolutely nothing wrong there. Don't fuck with it.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (04-26-2018) |
#8 |
Well, OK ......however, if the OP's pulley flies apart ....... it's on you .......
![]() ![]() humfrz |
#9 |
#10 |
You told him not to worry about it. Too bad for you.
#11 |
Drives: BRZ Premium
Eh.... any action is better than no action. Right?
![]() Now, just hold off a tad bit... let's see where this goes.
#12 |
Thanks for your input everyone, I just thought it was moving more than normal. I got a bit paranoid since getting the CEL's. Better safe to ask than sorry.
| The Following 2 Users Say Thank You to hyper4mance For This Useful Post: | Tcoat (04-26-2018), Ultramaroon (04-27-2018) |
#13 |
Nobody has really answered your second question though. If moving the pack seemed to work it may have just been a connection issue. Try moving it back again and see what happens.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (04-27-2018) |
#14 |
Okaly dokaly. Working on the other cars this weekend, so prob wont get around to this one for another week or two. Hopefully I'll remember to keep you posted.
| The Following User Says Thank You to hyper4mance For This Useful Post: | Tcoat (04-26-2018) |
| WTB: Rear Seat Belt Tensioner | michaelbuccola | Want-To-Buy Requests | 3 | 06-28-2022 01:07 PM |
| Aftermarket pulley wobble with video | killconey | Engine, Exhaust, Transmission | 62 | 02-15-2017 03:23 PM |
| SOS. Monterey area. Belt tensioner/belt | The Racers Line | Northern California | 11 | 04-06-2015 03:33 PM |
| Need V-belt tensioner torque value... | cobrabyte | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 10-10-2014 11:47 AM |
| driver belt tensioner | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-10-2012 06:44 PM |
