Old 04-18-2018, 08:03 PM   #239
alxtheoreo
alxtheoreo's Avatar
Originally Posted by kinghurl View Post
What year is your car?
Sent from my SM-G930V using Tapatalk
2013
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 04-18-2018, 11:18 PM   #240
kinghurl
Drives: BlueBurz
Quite a body of evidence to suggest this disproportionately affected 2013 cars. Oil weight?
kinghurl is offline   Reply With Quote
Old 04-18-2018, 11:30 PM   #241
alxtheoreo
alxtheoreo's Avatar
Eneos 0w20
Old 04-19-2018, 09:50 AM   #242
kinghurl
Drives: BlueBurz
OK, I'd been running 30w when my p0018 occurred as had some others, but some also ran the 20w as well so no trend there.
Old 04-19-2018, 09:59 AM   #243
alxtheoreo
alxtheoreo's Avatar
Yeah. I'm not sure what would cause it a second time, some two months later.
If they give me another new ECM, I'll convert the car back to stock so it'll be ready for sale.
Old 04-21-2018, 04:15 PM   #244
rusty959
Drives: DGM BRZ limited
I suspect your cam sprockets are broken and it takes awhile for the learning values to get far enough out of spec to throw the CEL.
rusty959 is offline   Reply With Quote
The Following User Says Thank You to rusty959 For This Useful Post:
Ultramaroon (04-21-2018)
Old 04-23-2018, 09:14 PM   #245
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
anyone have any success stories on this? got my code at 99k miles so it was out of warranty.
No engine roughness or idle issues. Just limp mode every 5-10 miles. Runs fine with code turned off.
P0016 code here. and tried swapping OCVs and sensors no luck and no change in code
2013 Subaru BRZ - SWP - 6MT
ShoGun is offline   Reply With Quote
Old 04-23-2018, 09:30 PM   #246
kinghurl
Drives: BlueBurz
That is the same as the p0018 except yours is passenger side. Had this happen twice. 1st time it took an OCV and ecu change to fix. This time it took a cam gear and ecu to fix. As much as you could call 2 times in 2 years a success story. No more codes or occasional limp home behaviours.
The Following User Says Thank You to kinghurl For This Useful Post:
ShoGun (04-23-2018)
Old 04-24-2018, 03:40 PM   #247
alxtheoreo
alxtheoreo's Avatar
Yup. They called me a few minutes ago to say that. They also want to replace the timing chain.
Estimated at $2500.
Old 04-24-2018, 03:47 PM   #248
TheStig85
Estimated at $2500.
Just the chain? $60 part but those labor charges O_o
Sent from my Pixel 2 XL using Tapatalk
TheStig85 is offline   Reply With Quote
Old 04-24-2018, 03:50 PM   #249
alxtheoreo
alxtheoreo's Avatar
This is to replace the timing chain, tensioners & cam gears.
Old 04-24-2018, 04:05 PM   #250
TheStig85
This is to replace the timing chain, tensioners & cam gear.
Ah, still pricey tho. I'd argue if you knew how to do it, to do it yourself. Or another shop that's not the dealer.
Old 04-24-2018, 04:11 PM   #251
alxtheoreo
alxtheoreo's Avatar
I called the two closest speed shops (Mach V & PTuning). Both are quoting near Toyota's estimate (about $200 less).
I would try to tackle this if I:
1- Had a second vehicle
2- Tools
3- Space
Old 04-24-2018, 04:20 PM   #252
Estimated at $2500.
Always replace chain and sprockets together. Good that they are doing that.
Given the job, $2500 is a reasonable quote. I'd have no trouble pulling the trigger if I trusted the guy doing the work. Good luck.
ShadowReaper (12-15-2024)
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 05:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-16-2021 11:09 PM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 02:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 03:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 09:24 AM
