Old 04-18-2018, 09:43 PM   #827
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Anyone have a PID for battery voltage? I searched this thread and Google.
Is "Voltage" via VControl Module or OBD Module accurate enough?
Thanks!
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 04-18-2018, 10:08 PM   #828
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Thanks!
Voltage is a standard obd PID, so using the one built into torque is fine.
Old 06-28-2018, 01:01 AM   #829
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
any one have luck finding out how to get oil temps to work again with the newer versions of oft tunes?
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline   Reply With Quote
Old 06-28-2018, 01:40 PM   #830
Yoshoobaroo
TRACKBREAD
Mine still works fine..
Old 06-28-2018, 01:41 PM   #831
Yoshoobaroo
TRACKBREAD
Does anyone have a PID for IAM?
Old 06-30-2018, 02:54 PM   #832
nico_rsx
Drives: BRZ 2017 Pure Red, MT
That would be really nice! But I am not sure you can read that with a standard OBD2 adapter. I've heard you need at least Techstream.
nico_rsx is offline   Reply With Quote
Old 06-30-2018, 03:40 PM   #833
Yoshoobaroo
TRACKBREAD
I thought there might be a chance since OFT can read it.
Old 06-30-2018, 03:54 PM   #834
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It might be a PID related to knock correction if you can find one,
Old 09-14-2018, 09:20 AM   #835
seekerof86
seekerof86's Avatar
Drives: 13' FRS
Does anyone have a working PID settings for the automatic transmission oil temp?
'13 FRS ultramarina 6AT fully stock
- mods in progress
seekerof86 is offline   Reply With Quote
Old 10-11-2018, 09:01 PM   #836
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
For some reason the PID for the oil temperature doesn't work but nothing else has any problems. The OBD2 device reports no errors on the Torque app.
Anybody got any ideas? I tried fiddling with all the various settings, connection speeds, unplugged, replugged in, restarted device, etc. It reads everything else fine.
I'm using an ELM327 Mini Interface.
Old 10-20-2018, 12:48 PM   #837
justingravy
Drives: 2015 scion frs
Hi, I've thrown a u0073 code but was able to clear it with the torque app. Now when I re-scan for fault codes, it shows "historic fault code u0073" lit up in green. I clear it but when I re-scan again, it shows the same thing "historic fault code u0073" lit up in green. Is this something I should be worried about? Is there a way I can clear it?
justingravy is offline   Reply With Quote
Old 01-08-2019, 04:26 AM   #838
Juzzotec
Juzzotec's Avatar
Drives: Toyota 86 GTS
Guys, the oil temp reading on my torque app reads normally then sky rockets to 6405c. I’ve tried with 2 different adapters? Has anyone had this issue or knows what’s up?
Juzzotec is offline   Reply With Quote
Old 01-11-2019, 05:36 AM   #839
Juzzotec
Juzzotec's Avatar
Just wanted to advise this was happening due to a cheap OBDII ELM327 clone from eBay. Upgraded to an OBDLink MX and no issues since, a bit overkill but problem solved
Old 01-19-2019, 04:47 PM   #840
Sgtfluffy16
Drives: White BRZ Limited
Originally Posted by Brody602 View Post
Oil Temperature PID credit to andreyiv:
PID setup for VERY accurate fuel remaining credit to developer:
so if i have the torque app and i do this set up i can view my oil temps in my 2014 BRZ?
Sgtfluffy16 is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
