#113 |
Yep. A Sunfire with a body kit. I just never could get over the front end on the 04 to 08 Lancers.
| The Following User Says Thank You to Tcoat For This Useful Post: | why? (04-14-2018) |
#114 |
Rice King
I can't see it, besides maybe the fogs.
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#115 | |
Drives: '13 FRS - STX
| The Following User Says Thank You to strat61caster For This Useful Post: | Tcoat (04-13-2018) |
#116 |
Drives: '15 BRZ RA
A quick note on tires. Not all performance tires will perform well on a 205/55 R16 size. The specific size is VERY demanding on the tire. Check here how much deformation has the Pilot Sport 4, which in other dimensions is considered a very good tire. This one has a 94Y XL specification and again the deformation is terrible:
![]() Check now the Advan A052 tire in same size. It is very similar with the A08b that was used in the first post video and has no deformation at all: ![]() Even if both tires had same rubber, the second one would outperform the first every single day. |
| The Following User Says Thank You to nikitopo For This Useful Post: | Tristor (04-17-2018) |
#117 | |
Rice King
Glorious Honda.
#119 | |
[insert cool phrase here]
Drives: BRZ Premium
Just the picture angles and distance are way off on both of your proofs. Simple logic bro.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#120 | |
Only users lose drugs.
Drives: All the time
Two different cars, two different angles, unknown pressures, etc. Comparing apples and guinea pigs in just about the most UNscientific of methods - random pictures from the intarweb. Also LOL that 205/55R16 is somehow a magic tire size that defies all normal tire behavior in any other size.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#121 |
Drives: 2017 86 860 Special Edition
An entire thread with speculation and apples to orange comparisons.
All things being equal a wider tire does more than just manage heat. Thus you need to consider slip angles, contact patch shape, tire spring rates etc. |
#122 | |
Drives: 2018 BRZ Limited, 2017 Sportage
And you are right, there is lots to consider about suspension and handling if you go far from OEM specs. |
#123 | |
#124 | ||
Drives: '15 BRZ RA
Here is my car: ![]() And I'll say again that it is not related with picture angle. The deformation is there in whatever angle. |
#125 |
Drives: '15 BRZ RA
Yes but more mechanical grip doesn't make you ALWAYS faster given that power is the same. This was the point of the original post. If it was so simple like swapping tires and wheels, then every manufacturer would provide their models with bigger combinations. The original comparison was of a much more expensive trim level with many changes but not on the engine power and a much cheaper trim level with not so many additions (the ra racing trim in Japan). The latter car outperformed the other one for a reason. But as the previous post some will argue that "the picture angle is not the same". Lol. Arguing just for the sake of arguing ...
#126 |
Drives: BRZ Premium
Again, way too many variables from both pictures.
How do you even know the exact conditions both tires are in? Was the picture taken before a run, after a run? Or was it just sitting pretty for hours in the hot sun? Hell, do you know if they purposely under inflated the tire right before their run? I don't want to be a **** but sometimes you just got to tap out sometimes.
| The Following User Says Thank You to Mr.ac For This Useful Post: | venturaII (04-17-2018) |
| What am I missing with all the ultra-wide wheels & tires? | Vdub | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 07-14-2017 09:08 AM |
| What are some good slippery narrow tires? | PowderfaceTr. | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 02-07-2015 01:14 AM |
| Tires that run wide or narrow | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 12-08-2013 04:55 PM |
| I have a 18x7.5+38 wheels..How wide can i go with tires | Bmore_Raven86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-23-2013 01:04 PM |
| 235 mm tires, great fit but not too wide | Black Tire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 02-07-2013 09:38 AM |
