Old 07-10-2012, 07:46 PM   #253
Don@Accelerated
Don@Accelerated's Avatar
V Band Setup is all done and welded up. Pics coming later. Just need to finish the oil lines now and were all ready to startup!
Don@Accelerated is offline   Reply With Quote
The Following 4 Users Say Thank You to Don@Accelerated For This Useful Post:
cobrabyte (07-10-2012), jedibow (07-10-2012), JiB (07-10-2012), LivingLegend (07-10-2012)
Old 07-10-2012, 07:49 PM   #254
slow_frs
Drives: turbo scion tc
Oil lines will take no time
slow_frs is offline   Reply With Quote
Old 07-10-2012, 07:52 PM   #255
Don@Accelerated
Oh and I ordered another wastegate. I'm going to step down into a Tial MVS instead of the MVR I currently have.
Don
Old 07-10-2012, 08:40 PM   #256
ahausheer
Re-member
Drives: Toyota camry
Why turbo as opposed to SC?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-10-2012, 09:01 PM   #257
slow_frs
Hey don since your already doing a scavenge pump for the return, I think you might want to consider the return from the pump being plumbed into the oil fill cap, this will be the most bolt on option I see and effective, I know I personally hate tapping oil pans, and since you have a pump then go for the fill
Old 07-10-2012, 09:48 PM   #258
DarkReign
DarkReign's Avatar
Drives: Raven FR-Sg, Mazda Rx7 FD
DarkReign is offline   Reply With Quote
Old 07-10-2012, 11:37 PM   #259
Don@Accelerated
I like the options!
Old 07-10-2012, 11:38 PM   #260
slow_frs
Originally Posted by Don@Accelerated View Post
I like the options!
Please tend to my question
Old 07-10-2012, 11:41 PM   #261
Don@Accelerated
I'll look into it tomorrow.
Old 07-10-2012, 11:42 PM   #262
Don@Accelerated
On to the pics!!!!!
The Following User Says Thank You to Don@Accelerated For This Useful Post:
kidgogeta (07-10-2012)
Old 07-10-2012, 11:44 PM   #263
Don@Accelerated
Picture of the first half of the overpipe. This pipe is composed of thick wall .109" 304 Stainless Steel. This would be considered heavy wall tubing. Much more rigid than the .065" we usually use. Less prone to cracking and I was also very worried about sag.
This pipe is seperated mid way by vband. The original design required the motor mount bolt be removed and the engine lifted. I wasn't a big fan of this so a redesign was in order. Now it goes in and out w/ no problems. Much easier to move than the factory piece.
The Following 2 Users Say Thank You to Don@Accelerated For This Useful Post:
cobrabyte (07-10-2012), LivingLegend (07-10-2012)
Old 07-10-2012, 11:47 PM   #264
Don@Accelerated
Pictured from the rear w/ nothing attached to it. Although it has a relatively low position. We are still 3/4" to an 1" above the front subframe. My car is lowered 2.5" and it still has adequate clearance just in case you hit a deer or a possum
cobrabyte (07-10-2012), wcbjr (07-11-2012)
Old 07-10-2012, 11:47 PM   #265
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
that would adding hot oil to the cylinder head... Better options
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-10-2012, 11:48 PM   #266
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
YES!!!!
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 12:24 PM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-04-2012 12:24 AM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 08:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
