Old 04-14-2018, 12:32 PM   #99
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I haven't seen V4, and didn't read this whole thread yet, but if Shiv has set IAM to 0.7 then I'd wager it's by design and whether the car runs at 1.0 or 0.5, it's working as exactly as intended with full power.
Meaning between that file and previous files where the timing has been adjusted so that IAM doesn't drop, the difference in timing is going to be fuck all.
The Following User Says Thank You to Wayno For This Useful Post:
Teseo (04-14-2018)
Old 04-14-2018, 07:42 PM   #100
Jasonb
Drives: 17 Series Yellow BRZ
So you're saying it won't make less power at .7, than at 1.0? That can't be true.
Jasonb is offline   Reply With Quote
Old 04-14-2018, 10:05 PM   #101
coxxoc
I'm pretty sure what he means is the ECU would have pulled timing before if the map was too aggressive for the fuel being used. If the engine couldn't handle 1.0 IAM before, it won't be able to handle it now. Starting at 0.7 will reduce timing for a short time. The IAM value should go up to 1.0 during operation so long as knock events aren't detected.
If you want to start out running max timing and the ECU pull it if knock events occur, change "Ignition Timing -Knock Control > Advance Multiplier (Initial)" to 1.0000. This only applies to the gasoline ROMs. The E85 ROMs stayed at 1.0 initial IAM since it isn't as knock prone.
coxxoc is offline   Reply With Quote
Old 04-14-2018, 10:34 PM   #102
Jasonb
On the V4 tune I'm using I set it at .9 so it takes less time to get to 1.0. I always have 93 available. Still safer than starting at 1, but I get more power right away, and max power sooner.
Old 04-14-2018, 10:58 PM   #103
coxxoc
Your approach is reasonable so long as logs aren't showing IAM dropping or a significant number of knock correction events. The 0.7 is for folks with lower octane fuel since Shiv merged the 91 and 93 octane maps into one.
The Following 2 Users Say Thank You to coxxoc For This Useful Post:
Jasonb (04-15-2018), Teseo (04-15-2018)
Old 04-14-2018, 11:10 PM   #104
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I do the same, it would take 40 mins of driving to get to .94. now it jumps to 1.0 as soon as it's warmed up.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Jasonb (04-15-2018)
Old 04-15-2018, 04:14 AM   #105
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
If it jumps to 1.0 very quick.. Why not just set it to 1. Apparently your fuel is good enough, that's what I see the EU guys doing, the fuel is good enough and the iam is always 1 on v4, so we set it at 1 right away.
Vin is offline   Reply With Quote
The Following User Says Thank You to Vin For This Useful Post:
Jasonb (04-15-2018)
Old 04-15-2018, 08:02 AM   #106
Jasonb
Eventually I probably will. I was just chasing down an issue of false knock. Once I'm completely sure everything is good then I'll probably do that.
The Following User Says Thank You to Jasonb For This Useful Post:
Vin (04-15-2018)
Old 04-15-2018, 12:37 PM   #107
churchx
churchx's Avatar
Drives: 2014 GT86
Vin: there always might be some exception, like filling up mid long trip not at tank one usually fills at. Or at one that has just ron 91. Imho it won't hurt to have slight safeguard left. Damn, at this point i'd love to see ecutek's multiple map switching with cruise control stick ported also in OFT. If one can put in support for some sensor/switch even if not found out how to read cruise control stick inputs, imho should be doable, as flexfuel that is possible with OFT, already switches between maps according to fuel sensor. I'd love to get my main tune, and one extra-safe one if with unknown fuel or ron 91 fill, without doing any reflashing.
Old 04-15-2018, 03:22 PM   #108
Vin
Vin's Avatar
The safeguard is the same? The ecu has room to compensate, it will adjust according to the fuel. If your fuel at home is good enough for iam 1, I'd just set it to 1. I have ecutek but use the map switching mostly for extra features (rev match, pops, LC etc). The fuel here in Europe, at least in my area, is so constant that I don't need a safe map. If I do run out of eu98 I'll just stay away from the redline, seeing different maps for different fuel have the most timing difference above 6k rpm (like Wayne roms Ron 98 vs 100 vs 102), just let the ecu do its work this whole iam debate should get a different thread, takes the focus away from the nice results the OP had with his dyno testing.
Old 04-17-2018, 03:58 AM   #109
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I've used the v2 maps in the past and the support of the v4 maps is not the same. The v2 maps were different per rom id and fuel type. Now he is trying to put everything in a single bag. I just don't like this change and that's all.
Old 04-17-2018, 04:32 AM   #110
tomm.brz
Drives: brz 2017 hksv2
Then don't use it? or do yourself the changes there are made in the v4 directly in the v2 if you want to try it
Old 04-17-2018, 12:36 PM   #111
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't use it
Old 04-17-2018, 01:35 PM   #112
Jasonb
They are made for 91/93 and made to work best with the UEL open flash header. So if you're using 93 and a UEL header like I am it'll work very well. Can't be a huge difference between the open flash header and the JDL.
don't read past page 1
Willowbrook Mall Parking Lot Meets - Thursday nights - Wayne NJ Jfheisenberg NY / NJ / CT / PA 487 07-15-2021 08:27 PM
Do dynos lie? nikitopo Engine, Exhaust, Transmission 21 05-10-2017 09:32 AM
Perrin CAI - Any dynos? griffinnn Engine, Exhaust, Transmission 0 03-14-2014 05:56 AM
Fort Wayne, IN Owners? Achpoques Great Lakes 4 07-20-2013 06:35 PM
Red Scion FR-S in Fort Wayne, IN BugeyedWagon Scion FR-S / Toyota 86 GT86 General Forum 3 07-22-2012 07:30 PM
