Drives: Civic Si coupe
driver belt tensioner
mine shake like mothaflocker. i took it to the dealer they said it's normal. is it true?
#2 |
Drives: 2013 MT Asphalt Scion FR-S
Mine shakes too.
#3 |
#4 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
It's an automatic tensioner. Essentially the pulley is mounted to a spring-loaded arm. As the belt changes tension due to variances in the load of the engine, alternator, waterpump, and A/C compressor, it will move to keep the belt at the proper tension. So some movement is normal.
Now if it's moving enough that you can see the belt jumping around between the other pulleys, then there's something wrong and it should be replaced. |
| The Following User Says Thank You to Draco-REX For This Useful Post: | Lowellrenzo (07-10-2012) |
| Removing and Replacing your BRZ/FR-S Accessory Belt | GrimmSpeed | DIY (Do-It-Yourself) Guides | 12 | 04-25-2019 05:53 PM |
| Seat belt issues | skoodge | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 08-04-2014 04:41 PM |
| Red Seat Belt - where to get? | MarkMash | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 06-24-2012 12:55 PM |
| Subaru seat belt chime | chitownwrx | BRZ First-Gen (2012+) — General Topics | 20 | 05-04-2012 03:35 PM |
| You wish you were this seat-belt! | YukiHachiRoku | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 05-03-2012 08:43 PM |
