Old 07-10-2012, 06:04 PM   #1
Lowellrenzo
Drives: Civic Si coupe
driver belt tensioner
mine shake like mothaflocker. i took it to the dealer they said it's normal. is it true?
Lowellrenzo is offline   Reply With Quote
Old 07-10-2012, 06:36 PM   #2
Stevieray
Drives: 2013 MT Asphalt Scion FR-S
Mine shakes too.
Stevieray is offline   Reply With Quote
Old 07-10-2012, 06:41 PM   #3
Lowellrenzo
Originally Posted by Stevieray View Post
Mine shakes too.
mine shake like it's about to jump off
Old 07-10-2012, 06:44 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
It's an automatic tensioner. Essentially the pulley is mounted to a spring-loaded arm. As the belt changes tension due to variances in the load of the engine, alternator, waterpump, and A/C compressor, it will move to keep the belt at the proper tension. So some movement is normal.
Now if it's moving enough that you can see the belt jumping around between the other pulleys, then there's something wrong and it should be replaced.
The Following User Says Thank You to Draco-REX For This Useful Post:
Lowellrenzo (07-10-2012)
Removing and Replacing your BRZ/FR-S Accessory Belt GrimmSpeed DIY (Do-It-Yourself) Guides 12 04-25-2019 05:53 PM
Seat belt issues skoodge Scion FR-S / Toyota 86 GT86 General Forum 55 08-04-2014 04:41 PM
Red Seat Belt - where to get? MarkMash Cosmetic Modification (Interior/Exterior/Lighting) 11 06-24-2012 12:55 PM
Subaru seat belt chime chitownwrx BRZ First-Gen (2012+) — General Topics 20 05-04-2012 03:35 PM
You wish you were this seat-belt! YukiHachiRoku Off-Topic Lounge [WARNING: NO POLITICS] 13 05-03-2012 08:43 PM
